Door Aperture Dimensions
9 replies to this topic
#1 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 26 January 2018 - 07:16 PM
Evening all
I was hoping that somebody would have the dimensions / or be able to measure from an unmolested shell, the height of a Mk4 door aperture.  Mine over the years has had a number of "fixes" with oversills and dodgy door step replacements, so i dont really have a datum to work to with the new door steps, and i would very much like it to be right.
Much appreciated
Andy
#2 Wizzalong
Wizzalong
  • 100 posts
Posted 02 February 2018 - 09:01 PM
I have measured mine before removing floor and then bracing, will post tomorrow.
#3 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 03 February 2018 - 09:40 AM
Brilliant, thank you very much.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,074 posts
  • Name: Neil
Posted 03 February 2018 - 10:28 AM
What’s annoying me I have put some on TMF and for the life of me I cannot find them. No access to my laptop for a week otherwise I could have posted up some more.
#5 Wizzalong
Wizzalong
  • 100 posts
Posted 03 February 2018 - 04:31 PM
Here are my measurements;  from edge of flanges top to bottom of door aperture, taken at two positions 888mm. and front to rear 875mm.
#6 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 03 February 2018 - 06:24 PM
Thanks Wizzalong, very much appreciated.
Sonikk, its no rush as im away for a week so wont get any work done on it now.  Would be good to get some others for comparison.  I did a lot of googling myself and couldnt find anything, other than the normal shell dimensions.
Andy
#7 sonikk4
sonikk4
  • 16,074 posts
  • Name: Neil
Posted 03 February 2018 - 06:43 PM
Andy
I wont be back at ours until next weekend. if i remember then i will post the picture then.
#8 absx2
absx2
  • 919 posts
Posted 03 February 2018 - 09:14 PM
To be honest it would be better to use an original unrepaired door as your reference points as there are too many variables to measure with true accuracy, like the slight curve in the door step section that follows the door bottom for instance.
#9 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 04 February 2018 - 11:48 AM
Ultimately i will do that.  But i currently have bracing stopping me from putting the door on.  I have had a measure of what i have now and its bouncing around the 888 by a few mill.  The current door steps have been bodged over the top of the originals and various oversills and inner sills have been put in over the years.  I have changed the full floor, toe board and now door steps, inner wings and a post stiffeners, so i need some rough measures to check what i have is ok enough to work off.  In hindsight i should have changed the door steps first before i did the floor, but will put that down to inexperience.
Measure twice, cut once an all that....
Andy
#10 pete l
pete l
  • 1,374 posts
Posted 05 February 2018 - 09:03 AM
Neil, You sent me some meassurements a year or so ago on here, can't find them either
