Painting Manifold.
13 replies to this topic
#1 myminipickup
myminipickup
  • 152 posts
Posted 02 February 2018 - 11:15 AM
Hello.
I've got a new Maniflow exhaust manifold - would you paint it or leave it? Obviously its mild steel, so its going to rust.. but will the paint protect it a bit or isn't it worth painting it?
#2 nicklouse
  • 18,652 posts
Posted 02 February 2018 - 11:55 AM
as yet I have not found any high temp paint that does not burn off.
but it is not a bad idea to do it. but what paint.
#3 Cooperman
  • 23,310 posts
Posted 02 February 2018 - 11:58 AM
Even ultra-high-temp paint only seems to last a couple of weeks before it burns off.
#4 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 02 February 2018 - 12:10 PM
This Ceramic paint claims to be stable upto 1000 degrees
Would need to sandblast the part before spraying it on.
#5 myminipickup
myminipickup
  • 152 posts
Posted 02 February 2018 - 12:59 PM
OK thanks for your help... I thinking I should just leave it unpainted ...sounds like it could be more problems than its worth!?
#6 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 02 February 2018 - 01:28 PM
Does wrapping a mild steel manifold prevent corrosion, or make it worse? I notice the standard manifold on my car is wrapped, but I also have a maniflow replacement to go on when the engine is rebuilt.
#7 nicklouse
  • 18,652 posts
Posted 02 February 2018 - 01:35 PM
it hold moisture so increases corrosion. it also moves the heat down the pipe which results in a hotter exhaust under the car which can burn off paint.
#8 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 02 February 2018 - 01:53 PM
Thought so. See a fair bit of corrosion under insulation in my day job!
#9 Dusky
Dusky
  • 5,322 posts
Posted 02 February 2018 - 02:07 PM
I have 1 Paint that survived a few years on my manifold. It was a silver high temp paint, but I cant recall the name. Was something like ' K-brake' orso. OR K-line
#10 Cooperman
  • 23,310 posts
Posted 02 February 2018 - 04:51 PM
A manifold will get to just below 'red' heat, so it would need a pretty special paint to withstand that.
You don"t really see the manifold and a manifold is unlikely to rust through.
#11 GraemeC
GraemeC
  • 7,439 posts
Posted 02 February 2018 - 09:01 PM
Barbecue paint works for a while, but burns & flakes off after a bit.
#12 Dusky
Dusky
  • 5,322 posts
Posted 02 February 2018 - 09:38 PM
https://www.spraydos...-c-silver-400ml
Auto K was the name. atleast I got the K right :P
Even survived my timing fiasco
#13 nicklouse
  • 18,652 posts
Posted 02 February 2018 - 09:52 PM
burnt that stuff quite a few times but it is on of the better ones.
#14 Compdoc
Compdoc
  • 612 posts
Posted 03 February 2018 - 09:55 AM
Frost sell VHT flame proof, supposed to be good. 700c or over 1000c with heat treatment, on or off the car.
http://www.ebay.co.u...119.m1438.l2649
