Mpi Radiator Removal
8 replies to this topic
#1 Glenny1481
Glenny1481
  • 41 posts
Posted 05 February 2018 - 08:51 PM
I started taking my radiator out quite late tonight and it was dark and freezing cold maybe making it a bit easier for me to get annoyed and chuck it for the night.
Basically I have everything disconnected from the radiator and the fan off but I can't get the radiator out, thinking I need to take the alternator out id someone could tell me if that's right or not that would be useful. And if you do how exactly do you go about doing that with the belt and what not. Not sure if I'm maybe just being daft and there's an easy way to get it out that I just can't seem to find or if there's a specific way it comes out that involves more removing of parts.
Any help appreciated, Cheers Glen
#2 MikeRotherham
MikeRotherham
  • 990 posts
Posted 06 February 2018 - 02:39 PM
On this page: http://www.theminifo...c=55958&&page=3 there is a link to a pdf of MPI workshop manual.
Removal of radiator is on page 158
Hope that helps
Edited by MikeRotherham, 06 February 2018 - 02:43 PM.
#3 Glenny1481
Glenny1481
  • 41 posts
Posted 06 February 2018 - 03:35 PM
Thanks very much I'll give that a go
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 February 2018 - 08:28 PM
You will need to remove the alternator. The belt can be removed easily by winding off the adjuster which looks like a threaded bar accessed from underneath under the alternator. You have to turn the adjuster clockwise to slacken it
Ben
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 February 2018 - 08:31 PM
The adjuster can be seen circled in red on this photo
#6 Glenny1481
Glenny1481
  • 41 posts
Posted 06 February 2018 - 09:16 PM
Well I got the radiator out, but, I also sheared the threads for the tensioner. I can't find the tension adjuster bolt or spindle as I've seen it called anywhere. What do i do now because I really need my car back???
#7 Steve220
Steve220
  • 5,075 posts
  • Local Club: BMC
Posted 07 February 2018 - 10:13 AM
Glen - can you show us which bits you mean? Someone maybe able to help.
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 February 2018 - 07:14 PM
https://www.ebay.co....noAAOSwtnpXj02C
#9 Clarkeatron
Clarkeatron
    Starting My Mini Up
  • 2 posts
Posted 02 May 2019 - 09:08 PM
This spindle caused me an absoulte nightmare. I ended up removeing the second bolt ont the panel  because i couldnt get the top bolt to shift. Ths allowed me to move the panel across so that I could reove the spindle assembly. The c-clip at the bottom was nowhere to be seen. I ended up having to heat up link for the adjuster to get it moving. It was going nowhere. Whilst i was there I ended up filing the head from the weird size 7/18's? to an 11mm size so that i could use standard tools. I also used copper grease on the thread to protect it after a deep clean
http://www.minispare...n.aspx?2~12~114
The assembly went back together really well.
Id love to know where i can get the c-clip becuase i cant seem to find it in mini spares?
Does anybody have a link to buy one?
