2K Clear Over 2K Acrylic Base
Posted 14 February 2018 - 09:45 PM
I ran out of colour and When I've gone on Jawels website to reorder the product I seemed to have brought is described as "high gloss" and "no need to apply a topcoat". All this time I had it in my head I was just using a 2k basecoat.
So front end is looking fantastic, very pleased with the finish but now I'm unsure whether it's going to cause me problems further down the road once it comes out the garage and into the elements - if I do the rest of the car as I did the front.
I've googled it to death but people are referring to either acrylic colour,or solvent basecoats.
Any advise whether to push forward with 2k over 2k acrylic, or redo the entire car with 2k of solvent basecoat and lose the front end hours of work and good paintwork.
The base/colour Ive used is octoral octocryl it appears from cross checking the reference numbers.
Posted 14 February 2018 - 10:01 PM
2k over 2k-1.jpg 77.77K
2 downloads
2k over 2k-2.jpg 32.22K
2 downloads
2k over 2k-3.jpg 69.04K
2 downloads
Posted 14 February 2018 - 10:12 PM
If the paint you have used is standard 2K direct gloss and you have lacquered this then you should be fine although its not strictly necessary. I have done this many times previously and have found that on red colours it works really well and gives a brilliant shine but on other colours (especially dark colours) it can act a bit like a magnifying glass and highlight any imperfections under the paint (sanding marks etc.).
Posted 14 February 2018 - 10:36 PM
Posted 15 February 2018 - 07:41 AM
Assuming I understand the scenario correctly - check the application instructions for your new single-stage paint (i.e. color coat that doesn't require a clear coat over it.)
The product will have a maximum time to apply a clear coat over it. Once this time period is exceeded, you will have to flat the color coat with an appropriate grade of abrasive paper to give the clear coat something to adhere to.
If you don't flat it, and you exceed the time window, the new clear coat will just peel off in time. The reason for this is that within the time window, the color coat is still chemically linking its molecules for maximum hardness. If you clear coat within the time window, the clear coats' molecules will link to those of the still-hardening color coat, creating a inseparable bond. Once the color coat's chemical hardening process is complete, the clear will have to rely solely on mechanical adhesion, and a slick, smooth surface offers very little for the clear to stick to.
Dave
Posted 15 February 2018 - 10:34 AM
Posted 16 February 2018 - 07:01 AM
I'm sure it will be fine. If nothing adverse has happened by now, nothing will (i.e. bubbles underneath.) And it sounds like you were supplied with a matching product system, so the clear will only enhance the durability and potential shine of the paintwork (especially for a lighter color.) In a matched system, the two items will of course work together if properly applied.
After flash time is usually sufficient, though ~20 min. is a bit on the short side for most products. But different systems vary, and if it flashed off properly then that's the primary issue. Looking good!
Dave
Posted 16 February 2018 - 09:24 PM
Posted 17 February 2018 - 08:42 PM
im a little confused by whats going on here, you say the basecoat is 2k, did it have hardender in it?
Posted 18 February 2018 - 10:11 AM
Posted 18 February 2018 - 11:15 AM
Sounds like you've used a 2K Direct Gloss. Designed to be used on its own. You can 2K clear over this perfectly fine too.
Posted 18 February 2018 - 09:41 PM
