Im after some advice on bleeding my brakes. Its a single line circuit, Ive just fitted new calipers and the front half of the braking system is dry, but there is fluid in the line going to the rear brakes.
Whats the best way to go about bleeding this? Should I get fluid to the fronts, then go back round and do furthest from master and so on? Also I think I read that single line circuits bleed in the opposite direction, passenger front first, then drivers front, pass rear, driver rear
Any help would be appreciated
