Cylinder Head Without Bypass
Posted 17 February 2018 - 11:43 AM
I have acquired a cam4810 unleaded cylinder head which I plan to put on my 1979 mini. There is no bypass on the head so presume it's off a metro. Do I buy a sandwich plate and run a hose from the sandwich plate to the bypass on the water pump or would this not be sufficient?
Mayhem
Posted 17 February 2018 - 12:01 PM
Some people manage without. The idea is just to get water circulating around the closed thermostat so it senses when the engine heats up better.
Posted 17 February 2018 - 12:50 PM
or drill out the hole. after checking that the bolt holes are there and threaded. if the holes are there but not threaded than they will need drilling and threads cut.
Posted 17 February 2018 - 01:19 PM
Posted 17 February 2018 - 01:27 PM
opps sorry miss read it. you dont need to do anything. just make sure the thermostat has the small hole on the side.with the wiggly thing in.
nothing needed to be done. no drilling no sandwichplate. engine will warm up faster and the thermostat will do what it should do.
Posted 17 February 2018 - 03:06 PM
Posted 17 February 2018 - 03:13 PM
i would tap it out and fit a grub screw. but then again what age it is? i may just be easier ti replace with new without the take off. but keep the old as a spare...
Posted 17 February 2018 - 03:16 PM
Posted 17 February 2018 - 05:35 PM
I just capped mine off with a short hose and a bolt in the end. Worked fine. No leaks.Thanks will do that. I will need to change the water pump won't I as it has bypass or can I cap it off?
Posted 17 February 2018 - 05:49 PM
