Indicators No Longer Flash.
10 replies to this topic
#1 Chris1992
Chris1992
  • 2,022 posts
Posted 18 February 2018 - 11:48 AM
Hi guys, so I've recently fitted a set of the Ultimate LED rear light conversion units, and at the same time my indicators have decided they no longer wish to flash, they do still light up though. I should mention this hasn't effected the hazard lights at all... I'm not sure if these two factors are linked, as I always assumed LEDs would make indicators flash faster rather than prevent them flashing at all. Is it as simple as the fact I have the wrong ticker/relay? Or have the LED's upset the current and something needs to be added to the circuit? Sorry if this sounds a bit daft, electrics are not my strong point!
Here is a link to the kit I have fitted: https://www.ebay.co....872.m2749.l2649
Any help would be much appreciated.
Chris
Edited by Chris1992, 18 February 2018 - 11:49 AM.
#2 Ethel
  • 26,089 posts
Posted 18 February 2018 - 02:16 PM
The indicator flasher (old style bimetallic type) relies on the current flowing through it heat the strip and make it flash. leds don't draw as much current so it's probably not heating up. Hazards work the other way round: the contacts are open until you flick the switch, an internal heater warms up, turns 'em on, the current can the bypass the heater so they cool down - the loop repeats...
Get yourself an electronic flasher flasher unit if you want to keep the leds.
#3 1984mini25
1984mini25
  • 8,785 posts
Posted 18 February 2018 - 02:24 PM
Stupid question. I replaced my flasher and hazard relays for electronic ones a few years back, but if I changed to led bulbs would I then need to change the electronic relays for led relay ones?
#4 Chris1992
Chris1992
  • 2,022 posts
Posted 18 February 2018 - 03:12 PM
Thanks for the help! Would something like this do the trick? https://www.ebay.co.uk/itm/12V-ELECTRONIC-INDICATOR-FLASHER-RELAY-FOR-CLASSIC-CARS-WITH-OE-CLICKING-SOUND/181707664784?hash=item2a4e9eed90:g:UVoAAOSwH3hZ~yzG
#5 Ethel
  • 26,089 posts
Posted 19 February 2018 - 01:10 AM
I can't see why an electronic flasher would be fussy as long as it can handle the current, which leds reduce.
but, I have thought of another issue - if you have a centre speedo the turn signal warning light earths via the indicators on the opposite side.
#6 Chris1992
Chris1992
  • 2,022 posts
Posted 19 February 2018 - 08:20 PM
I do indeed have a center speedo! If that is the route of the problem how would I go about fixing it?
#7 Ethel
  • 26,089 posts
Posted 20 February 2018 - 01:57 AM
I doubt it's the cause of the lack of flashing. Both sides might light regardless of indicating L or R.
Does the dash indicator still light now?
#8 Chris1992
Chris1992
  • 2,022 posts
Posted 20 February 2018 - 07:25 PM
 at the moment the indicators still respond to R and L, they just dont flash, and stay solid instead. The light on the dash does the same; comes on when indicating but stays solid.
#9 cal844
cal844
  • 9,650 posts
  • Local Club: TFMOC
Posted 20 February 2018 - 10:35 PM
Flasher relay
#10 Ethel
  • 26,089 posts
Posted 21 February 2018 - 12:57 AM
that's as you'd expect with bulbs, so it may work fine with just the new flasher.
#11 Chris1992
Chris1992
  • 2,022 posts
Posted 21 February 2018 - 08:34 PM
Ok will give it a try, thanks very much for all the help!
