Crankshaft Position Sensor
8 replies to this topic
#1 aml1989
aml1989
  • 25 posts
Posted 20 February 2018 - 11:52 AM
Okay, last stupid question - I promise.
Can anyone guide me in fitting the mounting bracket for the crankshaft position sensor?
I have the connector attached to the bracket, not sure where it mounts on the car. Black and white photo in the Haynes manual isn't clear enough to show where it goes and seem to have missed that one when taking photos of the disassembly...
Part 15:
http://www.minispare...C.aspx?2~20~189
Part 16:
http://www.minispare...~.aspx?2~20~190
Working with an MPI but guessing it's the same for both.
Thanks everyone,
- Andy.
#2 nicklouse
  • 18,600 posts
Posted 20 February 2018 - 11:54 AM
MPI sensor goes into the hole in the transfer case.
#3 Steve220
Steve220
  • 5,049 posts
  • Local Club: BMC
Posted 20 February 2018 - 11:56 AM
He means the connector mount.
Its held through the top starter motor bolt, the bracket lies relatively flat to the flywheel housing.
#4 Steve220
Steve220
  • 5,049 posts
  • Local Club: BMC
Posted 20 February 2018 - 11:57 AM
If you want a more detailed photo, i can get one tonight as I have it attached to the engine whilst its out.
#5 aml1989
aml1989
  • 25 posts
Posted 20 February 2018 - 12:01 PM
Brilliant! Will see if I can untangle my mess of wires and get it fitted.
Was trying it in the lower starter bolt without success, then ruled it out due to nothing being mentioned in the Haynes manual on refitting the starter motor.
Thanks guys!
#6 MatthewsDad
MatthewsDad
  • 814 posts
Posted 20 February 2018 - 01:22 PM
I have a pic on my phone. Pm me your email address. I can't compress the file size to upload here.
#7 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 20 February 2018 - 06:33 PM
If you create an imgur account you can post it on here and others will benefit from your skill behind the lens :proud:
#8 MatthewsDad
MatthewsDad
  • 814 posts
Posted 20 February 2018 - 10:16 PM
Here goes, the upper starter motor bolt holds it in position. It sits fairly flat.
#9 aml1989
aml1989
  • 25 posts
Posted 20 February 2018 - 11:20 PM
Got it!
Wouldn't have guessed that without you guys, many thanks!
I don't remember it coming off there and the cable didn't naturally rest that way.
I'm guessing my car was put together late on a Friday and someone at Rover wanted to go home...
