Mpi Ht Leads Sequence
Best Answer Itsaminithing , 21 February 2018 - 03:00 PM
  http://www.theminifo...order-confused/
Which Haynes have you got? 1969 to 2001 version has it clearly shown in section 5C3
Go to the full post
12 replies to this topic
#1 pete l
pete l
  • 1,372 posts
Posted 21 February 2018 - 10:10 AM
Hi all,
I'm having problems getting my MPI started and I've been reading about which way the HT leads go on the coil and plugs.
What is the correct sequence ?
Rover says one way, haynes say another, I've seen photos on ggogle that say something different !!!!
Thanks,
Pete.
#2 pete l
pete l
  • 1,372 posts
Posted 21 February 2018 - 10:22 AM
Just found this: what is correct ???
* Bottom left on the coil pack goes to plug 1
* Bottom right on the coil pack goes to plug 2
* Top right on the coil pack goes to plug 3
* Top left on the coil pack goes goes to plug 4
Or the other way
* Bottom left on the coil pack goes to plug 4
* Bottom right on the coil pack goes to plug 1
* Top right on the coil pack goes to plug 2
* Top left on the coil pack goes goes to plug 3
#3 mpialan
mpialan
  • 117 posts
Posted 21 February 2018 - 12:10 PM
In my experience Haynes Manual is correct!
I have a replacement Coil Pack on my car and, have often wondered whether there is a different sequence on the new one compared to that fitted in the factory.
#4 pete l
pete l
  • 1,372 posts
Posted 21 February 2018 - 02:35 PM
Rover book says 1.2.3.4. from bottom left goin around clockwise
Haynes says 1.2.3.4 going anti clockwise
then I see things like this
Attached File  3d6696ce7139edb38f6916f24546489c6da13eed.jpg   131.55K   6 downloads
I know they are wasted spark and that means there are different combinations but which is correct ?
Pete.
#5 pete l
pete l
  • 1,372 posts
Posted 21 February 2018 - 02:36 PM
That photo is 1.3.4.2. going anticlockwise
#6 Itsaminithing
Itsaminithing
  • 852 posts
  • Local Club: Not One Worth Mentioning
Posted 21 February 2018 - 03:00 PM   Best Answer
Edited by Itsaminithing, 21 February 2018 - 03:03 PM.
#7 pete l
pete l
  • 1,372 posts
Posted 21 February 2018 - 03:09 PM
OK, so my leads are on in the correct order.
#8 Ethel
  • 25,996 posts
Posted 21 February 2018 - 05:10 PM
The firing order is 1342 and it's a wasted spark so 1 & 4 will be on  one half of the coil pack and 3 & 2 on the other.All you have to do is get the correct pair on the correct half.
#9 jamesmpi
jamesmpi
  • 1,940 posts
Posted 21 February 2018 - 07:05 PM
https://imgur.com/a/G2SpN
This is the sequence on my mpi
#10 Itsaminithing
Itsaminithing
  • 852 posts
Posted 21 February 2018 - 07:10 PM
Pete once you have the car ready for the road it might be worth getting any fault codes stored on the ECU removed.
Took mine to a rolling road (one with a very good reputation) & it did run better after they had cleared the codes.
#11 pete l
pete l
  • 1,372 posts
Posted 21 February 2018 - 08:45 PM
thank you, so it is 1.2.3.4. clockwise from the bottom left.
#12 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 23 February 2018 - 01:50 AM
I am going to though something else in here.
I know that it is very possible to accidentally connect the wire connector onto the coil pack the wrong way round. First hand experience!! Check the wire connector is fitted in the correct orientation. The connector does have a 'key' location but if the connector is a little tired, can easily look like its on the right way, when in fact its not. Inspect it carefully making sure the key grooves in the connector plug match up with the key ridges on the coil pack.
#13 pete l
pete l
  • 1,372 posts
Posted 23 February 2018 - 07:42 AM
OK, will do.
Thanks.
