Attached are some readings from cold start, couple of minutes later and 15min on.
Any kind soul with experience can comment on anything I should be looking at? I checked the codes and nothing showed up although it appears the MAP reading is high (changing the hoses soon together with the fuel trap), the Lambda sensor reading doesn't fluctuate frequently as it is supposed to?
