Dsn Classics Engine Steady
11 replies to this topic
#1 70K1100
70K1100
    Formally Known as NOT850
  • 227 posts
Posted 01 March 2018 - 08:17 AM
I was reading either a mini magazine or miniworld magazine a while ago and saw a Mini which I think was yellow with a green roof that ran twin SU carburettors and the owners had used a dsn classics engine steady on the radiator end of the engine. Now I have looked at the dsn classics website so many times and they don't make the steady to suit twin SUs.
Now I have misplaced my copy of that magazine.
Does anyone know how much work it would take to make one fit. I have a 1970 Mini with a 1098 and twin HS2s.
#2 nicklouse
  • 18,600 posts
Posted 01 March 2018 - 09:05 AM
cant see why the small bore one would not be suitable for twin carbs. maybe they are just being careful.
#3 70K1100
70K1100
  • 227 posts
Posted 01 March 2018 - 09:25 AM
I don't know either unless the left hand carburettor interferes with the mounting point somehow.
#4 Spider
  • 14,893 posts
Posted 01 March 2018 - 09:31 AM
If you have the original gearbox you don't need a Radiator end engine steady as it uses the remote shifter housing for this.
#5 nicklouse
  • 18,600 posts
Posted 01 March 2018 - 09:46 AM
mounting point is the LHD pedal box area the exhaust is closer.
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 01 March 2018 - 10:01 AM
I would email them and ask them if it will fit.
#7 70K1100
70K1100
  • 227 posts
Posted 01 March 2018 - 10:35 AM
Moke spider I have a rod change gearbox so I'm looking at more stability for the engine unlike the remote gearbox. Northernpower I'll shoot them off an email if no one here can help. I was just thinking that the builder of the other mini may have moved the bracket on the right hand side of the firewall towards the outside of the car to get more clearance.
#8 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 01 March 2018 - 10:40 AM
I have one of their steadies and wanted it modifying. You'll find they're real helpful. I would not hesitate to email them.
#9 MiniMoe2008
MiniMoe2008
  • 163 posts
  • Local Club: None Around Here
Posted 01 March 2018 - 05:16 PM
Are you talking about the engine steady that holds the radiator thermostat housing? or underneath from the engine to the subframe?
http://www.dsnclassi...l-bore-engines/
http://www.dsnclassi...big-bore-short/
#10 nicklouse
  • 18,600 posts
Posted 01 March 2018 - 05:32 PM
here you can see how the MPi one is i am sure there is room for twin carbs
#11 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 01 March 2018 - 05:33 PM
If it's going to interfere with the carbs it's going to be the upper one. :proud:
#12 Mervyn
Mervyn
  • 256 posts
Posted 04 March 2018 - 08:40 AM
Oh dear, now I've found a website that's going to cost me a fortune
Merv
