Force Racing Rims
17 replies to this topic
#1 JakesTe
JakesTe
  • 51 posts
Posted 03 March 2018 - 05:30 PM
Can you share your pictures of mini's with force racing split rims please. especially 10 inch.
#2 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 03 March 2018 - 05:50 PM
My South African Mk3 :
#3 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 03 March 2018 - 10:34 PM
Centres repainted from orange, all rim bolts now in stainless, also stainless sleeve nuts
#4 Chris1992
Chris1992
  • 2,022 posts
Posted 05 March 2018 - 01:05 PM
My 13" Turbo TFs
#5 minimole23
minimole23
  • 32 posts
Posted 05 March 2018 - 07:52 PM
7x10, v2 centres and old style of outer rim with a more gentle radius. Lovely pieces of kit.
40597867112_d6d822714a_k.jpgIMG_0392 by , on Flickr
38829583880_9c21c3e101_k.jpgIMG_0395 by , on Flickr
#6 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 05 March 2018 - 08:11 PM
I used to have the exacton rims split by Force till more and more people got them split and I got bored of seeing them  :P
#7 JakesTe
JakesTe
  • 51 posts
Posted 06 March 2018 - 02:18 PM
just wondering, how do you like 7 inch wide wheels? do they affect driving at all?
#8 minimole23
minimole23
  • 32 posts
Posted 06 March 2018 - 08:29 PM
The 7x10 was an improvement over the previous 6x12's. Despite being 'wider' the centre has no built in spacer so they actually sit closer to the hub and further in the arches than the 6x12's. As for handling it was an improvement. Those are a 3.5"/3.5" inner and outer.
Edited by minimole23, 06 March 2018 - 08:30 PM.
#9 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 06 March 2018 - 08:54 PM
What size and make of tyre have you fitted to them?
#10 minimole23
minimole23
  • 32 posts
Posted 06 March 2018 - 09:02 PM
Yokohama A032's. 165/70/10.
#11 JakesTe
JakesTe
  • 51 posts
Posted 07 March 2018 - 01:20 AM
Interesting. Thanks for the info. Is there more torque steer? just wondering what its like with no power steering
Edited by JakesTe, 07 March 2018 - 01:21 AM.
#12 nicklouse
  • 18,740 posts
Posted 07 March 2018 - 01:46 AM
just a comment here Torque steer is i believe the wrong word. what i think you are asking about is tram lining. how the car behaves over imperfections on the road surface.
and how the car behaves has much to do with the suspension set up also having an ET close to/or zero can help.
#13 JakesTe
JakesTe
  • 51 posts
Posted 07 March 2018 - 02:48 AM
well tram lining too, but i did mean torque steer. like does it pull(turn) almost too much when going around corners fast?
#14 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 07 March 2018 - 09:57 AM
Torque steer is very common in a straight line and very often this is induced by high engine torque through unequal length driveshafts. The effect of oversteer or understeer when cornering fast is more to do with suspension setup. You ask about pull(turn) through fast corners, this is more commonly associated with incorrect corner weighting, suspension set up, tyres far wider than the original design parameters for the original suspension set up, hence the understeer or oversteer. I know Nick can answer for himself but technically he was correct in saying its more about tramlining. This is something I have experience of and I'll say it's almost impossible to dial out if you want the look of wide tyres on a road Mini. I have the worst of all worlds, high torque and 175x13 tyres. If you fit wide tyres with a standard engine, the cornering, while not being great, won't be as bad as a high torque output engine.
Edited by Northernpower, 07 March 2018 - 09:58 AM.
#15 nicklouse
  • 18,740 posts
Posted 07 March 2018 - 10:25 AM
un equal length drive shafts. torque steer sorry no. some great sales marketing.
