Re Using Sump Plug And Washer?
9 replies to this topic
#1 babsbrown
babsbrown
  • 496 posts
Posted 05 March 2018 - 09:31 AM
Good morning everyone, after hearing many horror stories about a stripped sump plug and / or sump thread, I've never replaced the sump plug/washer during an oil change. Would this be in anyway detrimental to the car? It's always been a nice snug fit thus never thought it necessary to replace it. Best regards, Babs
#2 nicklouse
  • 18,650 posts
Posted 05 March 2018 - 09:34 AM
the plug does not need changing. the washer if damaged should be changed. most people reuse the washer for many oil changes.
it should be a soft copper washer and some are not annealed to make them soft.
#3 CityEPete
CityEPete
  • 3,920 posts
Posted 05 March 2018 - 10:25 AM
I just swap the washer with each filter change
#4 Dusky
Dusky
  • 5,322 posts
Posted 05 March 2018 - 10:30 AM
They cost like 1£, i just replace them. Not worth draining new oil if it leaks.
#5 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 05 March 2018 - 11:01 AM
I agree with the above, for what they cost I just fit a new one. http://minispares.co...|Back to search
#6 nicklouse
  • 18,650 posts
Posted 05 March 2018 - 11:18 AM
unfortunately most of the new ones have not been annealed.
#7 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 05 March 2018 - 11:24 AM
I've never annealed the Minispares ones but it would be easy enough to do with a gas hob in the kitchen.
#8 CityEPete
CityEPete
  • 3,920 posts
Posted 05 March 2018 - 12:03 PM
Just get it to glow then cool it in oil?
#9 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 05 March 2018 - 01:59 PM
The A series likes o drop oil from just about everywhere, so the sump plug is usually the least of our worries  :-)
#10 babsbrown
babsbrown
  • 496 posts
Posted 05 March 2018 - 06:32 PM
Thanks for the advice. I heated the old one up on the gas hob until it was glowing then doused it in cold water. Refitted it and its tight not leaking, touch wood. Torqued it up to about 34Nm which seemed more than sufficient. Cheers, Babs
