Big End Ovality
7 replies to this topic
#1 suuper
suuper
  • 10 posts
Posted 11 March 2018 - 06:30 AM
Hi,
i am doing an 1275 Engine and need a little advice. I have measured the crank and the big end journals. Haynes say max. 0,025mm for crankshaft ovality. But is this also for the big ends? Max ovality at my crank journal is 0,008mm - fine! At the big ends it is between 0,010 and 0,012mm - which would be good also if the 0,025 applied for the big ends. I want to be sure - thanks for help!
cheers andreas
#2 Dusky
Dusky
  • 5,322 posts
Posted 11 March 2018 - 09:22 AM
0.01-.0.027 for the mains
0.01-0.025 for the big ends in my voor, for 1275 engines (rover manual)
#3 suuper
suuper
  • 10 posts
Posted 11 March 2018 - 09:43 AM
thanks a lot! cheers
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,746 posts
Posted 11 March 2018 - 10:51 AM
More important here is the diameter?
Ac
#5 suuper
suuper
  • 10 posts
Posted 11 March 2018 - 06:26 PM
yes - its a green one 12A - that diameters are listet in haynes. at this point everything is ok. and i will check it double with gauges.
but thank you for think twice!
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,746 posts
Posted 11 March 2018 - 06:56 PM
Do not use original data to compare the sizes too. You need to go by the data from the bearing manufacturer of the shells you intend to fit.
Ac
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,746 posts
Posted 11 March 2018 - 06:57 PM
The minimum size for after market shells (big ends) is usually 1.7504" not 1.7497" as quoted by the manufacturer.
Ac
Edited by ACDodd, 11 March 2018 - 06:57 PM.
#8 suuper
suuper
  • 10 posts
Posted 11 March 2018 - 08:22 PM
ok - thanks - i will spend attention. cheers andreas
