998 Cooper.. Standard Rocker Assembly
Posted 13 March 2018 - 07:20 AM
Posted 13 March 2018 - 10:32 AM
Do you want to buy a new rocker assembly for performance reasons or because the old ones are worn out? What spec is your engine?
You can buy new standard rockers, shafts, etc from the usual shops
http://www.minispare...ngs/CAM289.aspx
From there you can upgrade to higher ratio rockers like 1.3 and 1.5 ratio
http://www.minispare...s/C-AHT436.aspx
And also to roller tipped ones.
http://www.minispare.../C-AHT446A.aspx
Posted 13 March 2018 - 11:26 AM
Originally they had Pressed Rockers and unfortunately, they are well and truly NLA.
They can be rebulit though, the pads can be dress, the bushes replace and as Tim mentioned ^, the shaft can be replaced.
Other than that, the only new types available these days are performance types in one form or another.
Posted 13 March 2018 - 12:06 PM
thought so .. thanks all
they're worn out and very noisy .. I have bought a set from minisport for now, I'll try to get the originals rebuilt
