2000 Mini Cooper Sport Which Antifreeze?
5 replies to this topic
#1 DJC MINI
DJC MINI
  • 84 posts
Posted 13 March 2018 - 07:59 PM
Hi Guys,
My coolant has leaked due to a faulty heater valve. I've topped it up with water for now but obviously needs the correct antifreeze. All I know is that its a pinky colour (see pictures). I know Rover changed the coolant type at the end of production. Any ideas? If not how do I go about flushing it through to replace it with a different brand.
Any ideas?
Thanks,
Dan
Edited by DJC MINI, 13 March 2018 - 07:59 PM.
#2 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 13 March 2018 - 08:15 PM
the red longlife is the correct type for the mpi oat type
#3 DJC MINI
DJC MINI
  • 84 posts
Posted 13 March 2018 - 08:27 PM
Thanks. Would you recommend flushing it through anyway before adding the antifreeze
#4 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 13 March 2018 - 09:18 PM
always worth a flush through as heaters and heater pipes suffer on these cars
#5 nicklouse
  • 18,724 posts
Posted 14 March 2018 - 12:05 AM
from the manual.
UNIPART SUPERPLUS 3 ANTI-FREEZE AND
SUMMER COOLANT
If this is not available, use an ethylene glycol based
anti-freeze, containing no methanol with
non-phosphate corrosion inhibitors suitable for use
in mixed metal engines to ensure the protection of
the cooling system against frost and corrosion.
superplus 3 is NLA
#6 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 14 March 2018 - 10:35 PM
from the manual.
SUMMER COOLANT
superplus 3 is NLA
That is correct, however, Unipart sells a similar product https://unipartautos...e-5-litres.html
Colour doesn't mean much these days. You certainly cannot use the colour to identify what type of coolant it is.
Edited by Sprocket, 14 March 2018 - 10:37 PM.
