Camshaft Issue
Best Answer macaldron , 16 March 2018 - 03:45 PM
Update - Swiftune responded. It's a manufacturing issue.  The ball is supposed to be there, but it is not properly located.  They apologized, and a replacement cam is already on its way.  I'll be all set Mon!
Go to the full post
9 replies to this topic
#1 macaldron
macaldron
  • 17 posts
Posted 15 March 2018 - 05:28 AM
I am putting together a 1330 engine, and have run into an issue with the camshaft.  When I install the cam, then the oil pump, then the end gasket, timing plate and triangle thrust, the thrust will not sit flush on the timing plate - it binds on the end of the camshaft.  The camshaft is being pushed too far toward the timing gear in its bore. What seems like a the possible culprit is a metal ball inserted in the slot end of the camshaft, which is interfering with the oil pump. The oil pump driver contacts the ball, and when I properly bolt the oil pump to the block, the cam is shifted at least 1/16" too far, causing the binding.
Photo of the metal ball in the slot attached.
Has anyone ever seen this before?  Could there be something else going on?  Any insight appreciated! (I have already contacted the camshaft manufacturer...waiting for a response...)
#2 nicklouse
  • 18,687 posts
Posted 15 March 2018 - 09:01 AM
that should not be there.
#3 Spider
  • 15,100 posts
Posted 15 March 2018 - 09:27 AM
Has it been 'cross-drilled' for an oil-way through the Cam?
#4 nicklouse
  • 18,687 posts
Posted 15 March 2018 - 09:56 AM
looks like an SW5-07 don't think they are X drilled?
#5 macaldron
macaldron
  • 17 posts
Posted 15 March 2018 - 01:24 PM
There are holes in each lobe, so yes, cross drilled.
#6 Spider
  • 15,100 posts
Posted 15 March 2018 - 05:52 PM
Mmmm,,,, only a guess here, but I suspect that the ball is fitted to plug the oil-way through the cam, only it would seem that the drill wondered and the recess for the plug (a ball here) is not only in  a bad spot, but not deep enough.
If it's new, I'd be sending it back. If it's used, you may have to grind a wee bit off the spade of the Oil Pump.
#7 macaldron
macaldron
  • 17 posts
Posted 15 March 2018 - 05:58 PM
Thanks. Still trying to get swiftune to respond to this. I am on the west coast of usa, so while sending back seems like the best option, it's significantly inconvenient.
#8 Chris.Williams
Chris.Williams
  • 679 posts
Posted 15 March 2018 - 06:00 PM
I have a SW05-07 sitting on my bench at work, I'll have a look at mine and see if it has a similar ball.
#9 macaldron
macaldron
  • 17 posts
Posted 15 March 2018 - 06:15 PM
Thanks Chris!
Edited by macaldron, 15 March 2018 - 06:15 PM.
#10 macaldron
macaldron
  • 17 posts
Posted 16 March 2018 - 03:45 PM   Best Answer
