Regrinding The Crank On A Race Engine?
40 replies to this topic
#1 grizzler73
grizzler73
  • 300 posts
Posted 20 March 2018 - 10:35 AM
Hi Everyone
I have a std/std CAM 6232 crank for my GTM engine, my question is, is it ok to regrind to +10 on a race engine? as I have to use 1 1/4" SU's I can't see it revving much past 7000 rpm. I read somewhere that a 10 thou regrind has a negligible affect on the strength, is that true? Also on the same theme, is a centre strap necessary on a A+ block?
Ta
S
#2 Dusky
Dusky
  • 5,322 posts
Posted 20 March 2018 - 10:40 AM
Nothing wrong with a regrind.
I dont like centerstraps, they re way too expensive after line honing and do nothing some hardened washers couldnt do. Wich is what I use
#3 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 20 March 2018 - 10:43 AM
If you talk to Keith Calver, who's built a few race engines in his time, he doesn't fit a centre strap, just some APR washers on the main bolts.
#4 racingbob
racingbob
  • 3,061 posts
Posted 20 March 2018 - 11:27 AM
my historic 1293 Cooper s was ground 10 thou no problems
#5 grizzler73
grizzler73
  • 300 posts
Posted 20 March 2018 - 12:45 PM
I have to admit I was never convinced by the centre main strap as an idea anyway, the A+ one looks very strong. Can you clarify the washer comments? Do you add the ARP washers instead of the lock tab, any loctite used on the bolts?
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 20 March 2018 - 01:46 PM
No locktabs and no locktight on the bolts. You'll probably have to grind the end cap heads down a little to give clearance on the box due to the extra thickness of the washers.
#7 hhhh
hhhh
  • 422 posts
Posted 20 March 2018 - 02:21 PM
Why no Loctite? Thanks.
#8 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 20 March 2018 - 02:24 PM
You won't get an accurate torque.
#9 hhhh
hhhh
  • 422 posts
Posted 20 March 2018 - 02:32 PM
That makes sense that it would change the net clamping force, but I'm sure some engineer somewhere could calculate the adjustment required though for the wet torque. According to this: http://henkeladhesiv...ationship-2.pdf , torque is more consistent with Loctite than without since it reduces variability.
Edited by hhhh, 20 March 2018 - 02:37 PM.
#10 nicklouse
  • 18,587 posts
Posted 20 March 2018 - 02:40 PM
always run a strap on both A and A+ but we were/are pushing 8.5k
#11 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 20 March 2018 - 02:48 PM
If I were revving to 8.5k I'd be like you and fit a strap but the OP says he's only going to rev to 7k. A complete balance would be better value than fitting a strap.
#12 nicklouse
  • 18,587 posts
Posted 20 March 2018 - 02:51 PM
I would not not balance it anyway whatever the RPM I doubt the last build I did will see 6k but was fully balanced. (no strap by the way).
#13 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 20 March 2018 - 03:57 PM
I don't understand, why wouldn't you balance the bottom end of an engine?
#14 grizzler73
grizzler73
  • 300 posts
Posted 20 March 2018 - 05:07 PM
I think Nicks use of a double negative confused you, that is generally what they do  ;D
#15 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 20 March 2018 - 06:43 PM
Ok I understand, I just misread it; doh!
