Hi there,
I've been trying to get my suspension setup sorted out for Autosolos and road use. Finding somewhere was a bit of a pain so I tried to learn the old string and measuring tape technique. I've got it fairly drivable but just need a little advice to finish her off.
WP_20180327_19_13_24_Pro (2).jpg 56.59K
26 downloads
(12" Wheels)
I need to put less toe out on the fronts, and sort the toe in on the back (that one's a mess)
My real question is about the castor, as I didn't touch this - I just set the adjustables to the standard length.
So the right side in particular is a bit excessive (and I occasionally get rubbing on the arch when turning)
So I'm looking to bring both sides down to about 4 degrees all round.
Stupid question, but do I shorten or lengthen the tie bar to reduce the castor?
What effect is that likely to have on the camber/toe setting?
