Yes, the tool makes a big difference. Bit of patience and care needed to pick out the old seal but it does come out eventually.
Possible Oil Leak ?
sam138
, Mar 30 2018 07:10 PM
17 replies to this topic
#16
Posted 01 April 2018 - 06:00 PM
#17
Posted 01 April 2018 - 07:08 PM
It's not a problem if the primary gear does come out. If you use the proper tool it uses the primary gear to pull the seal out anyway.
#18
Posted 02 April 2018 - 09:30 AM
I use the tool but remove the primary gear and fit the seal over the gear on the bench then fit it on the engine then use the tool to push the seal home.
Edited by cal844, 02 April 2018 - 09:31 AM.
