Can anyone help with a starting issue with the Nodiz?
I fitted a Nodiz unit to a rebuilt engine and it just won't start. I get permanent Red LED on ignition and cranking, Flashing Blue and Green LED's on cranking but it won't fire. I'm getting fuel in the cylinders and a strong white spark from the plugs. The Trigger wheel is set to 90 degrees before TDC and with an old Dizzy inserted the Rotor arm points to 1 O'clock when number 1 cylinder is at TDC.
Is there anything else I can look at?
Edited by Zipimini, 31 March 2018 - 01:19 PM.
