It is only a thing casting section at that point. Over-tighten it could well have done it.
Tip: to get them to seal, use Muffle Putty in the joint then use a jack to hold the pipe in place while doing up the clamp.
Sounds like a well known Ausy yarn...must be a new Marino cross called a manifold...?
So I sheared my Manifold....not much wool on the bugger....hahahh
I wonder what muffle putty in the joint smokes like ?
Soz could not resist
In Aussie slang, the full translation can't be printed here, but a 'family' version of it would be along the lines of;-
" Maaaate, go see Johno, down the Servo, heeez got muffapuddie. Don't smoke it maaaaate, tastes like kangawillafox do-do. Make sure Johno puts a Jack-me-off unda it will ya "
