Whats Inside Late Jap-Spec Motors?
8 replies to this topic
#1 bubbacluby
bubbacluby
  • Just Joined
  • 57 posts
Posted 02 April 2018 - 11:12 AM
Hi
Blew my 99 Jap spec Rover mini engine up completely (Basically whole thing needs replacing).
This is a MPI block, but uses the Spi injection and 3.2 diff.
Buying a nos short mpi motor from mini-spares, but need to know a couple things:
* What camshaft would this be running (I need to replace the original). Spi or Mpi?
* Flywheel/clutch assume would be Spi (due to crank sensor)?
Thankyou for your help
Brenton
#2 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 02 April 2018 - 02:02 PM
MPi block, therefore MPi camshaft. The Japanese ECU on the late models uses the MPi flywheel too.
#3 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 02 April 2018 - 03:54 PM
Manual or automatic? massive difference in the block........
#4 bubbacluby
bubbacluby
  • Just Joined
  • 57 posts
Posted 02 April 2018 - 10:06 PM
Sorry should have said Manual 1275
#5 bubbacluby
bubbacluby
  • Just Joined
  • 57 posts
Posted 03 April 2018 - 10:35 AM
Thankyou for the reply Steve.
Are you 100% certain on this?
(As I need to buy new parts and then assemble motor and put it in car, just don't want to do all that and then find out something is wrong)
Thankyou Brenton
#6 nicklouse
  • 18,998 posts
Posted 03 April 2018 - 10:39 AM
wont you be using most of the existing parts?
the only thing that you really need to check is the camshaft.
#7 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 03 April 2018 - 10:55 AM
Thankyou Brenton
I go on what minispares state on their website
#8 bubbacluby
bubbacluby
  • Just Joined
  • 57 posts
Posted 03 April 2018 - 11:09 AM
had a conrod break and likely smashed up against the camshaft, so replacing to be on safe side.
Flywheel had to be cut off as had welded to crank and wouldn't budge.
Hence why they need replacing
Thankyou Brenton
OK, Thankyou, I didnt know it was mentioned on the mini-spares site
Thankyou all
#9 hungdynasty
hungdynasty
  • 179 posts
Posted 04 April 2018 - 10:16 AM
I always find that Somerford's catalogue is more clear on parts for jap spi.
https://www.somerfordmini.co.uk/eshop/
