Cam Choices
5 replies to this topic
#1 pinkmini99
pinkmini99
  • 563 posts
Posted 02 April 2018 - 07:32 PM
Hi folks Im looking for a good 998cc fastroad cam choice
#2 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 02 April 2018 - 08:21 PM
Is the engine modified in any other way ?
Do you know what diff gearing you have ?
Are you prepared to put up with a slightly lumpy engine tick over ?
#3 pinkmini99
pinkmini99
  • 563 posts
Posted 02 April 2018 - 08:28 PM
No other mods as of yet and yes willing to put up a lumpy cam
#4 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 02 April 2018 - 08:52 PM
Kent 266.
#5 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 02 April 2018 - 08:54 PM
The 1st mod on any A series should be a cylinder head, a 12g295 works well on a std 998.
Standard combustion chambers, valve sizes and port throats are not the best
You won't see any significant gains until you replace the head.
Head Cam exhaust and inlet manifold you will have a good boost.
#6 Turbo Phil
Turbo Phil
  • 2,427 posts
Posted 02 April 2018 - 09:40 PM
If the engine is completely standard I'd be spending my money on a decent (Minispares) stage one kit, that will give you the biggest power increase for the cost. You will see a gain from fitting a performance cam, but not a lot unless (as suggested above) you fit a better, or modify your cylinder head. 12G295 heads go for stupid money now & the stock 998 head can be worked to give decent results.
Phil.
