Shaft Issues
Posted 05 April 2018 - 12:43 PM
Thanks.
Paul.
Posted 05 April 2018 - 12:50 PM
diff end? inner part on the driveshft the wrong way round?
Posted 05 April 2018 - 01:26 PM
Posted 05 April 2018 - 07:00 PM
The spider and balls on the inboard CV with stock parts sit quite close to the outer end of the CV itself.
If you've got worn rubbers on the inner of the lower arm or loads of neg Camber, then it's quite easy for the balls of the inboard CV to just pop clear on the CV bell. It will make quite a noise and you'll loose drive. This is much more pronounce on suspension droop, so when cornering, this can occur on the inboard wheel.
Posted 05 April 2018 - 09:07 PM
I'll dive check everything suspension wise though.
Thanks moke
Posted 11 April 2018 - 05:39 PM
Posted 11 April 2018 - 09:11 PM
Does it crunch in reverse ?
It has been known for the diff pinion nut to come loose....
It can make all sorts of noises in the 4 forward gears, the tooth angle on the crown wheel and pinion pushes the pinion out, hence the crunching.
In reverse the tooth angle pulls the pinion in and it will drive OK once engauged.
Hopefully its not.
Posted 11 April 2018 - 09:52 PM
Posted 11 April 2018 - 09:55 PM
Posted 11 April 2018 - 10:45 PM
i would say engine mount and popped drive shaft partially engaged but not enough.
Posted 11 April 2018 - 11:54 PM
We are all assuming the clutch works fine...Could be drive shaft issue or diff pinion.
Your description of the bike chain jumping and it starting when cornering makes me think its a pot joint giving up.
Make sure you are on a reasonably flat surface, with bonnet up
Jack the front up and support it well on 2 axle stands.
Scotch the back wheels and make sure the handbrake is well on
Start the engine put it in 1st and have a look...both wheels should turn, but might not.
It will be better with 2 people, the 'driver' can then try a bit of gas and a bit of left foot braking to act as load. You may then be able to diagnose it better.
If its the pot joint spider or balls; the driveshaft on one side might not be turning properly, and the pot will be, having some load should help, you can hopefully make it make the same sort of noises.
If its a driveshaft not engaging the CV joint splines; the shaft will turn and the wheel will stop under brake load.
The driveshaft is an easy fix, a loose diff pinion is engine out / spit / rebuild scenario.
I have known the pot joint balls / cup to give a reverse only Mini.
Good luck, and please be careful
Posted 25 April 2018 - 08:45 PM
Im fearing the worst here. Any other ideas? I did try all gears with driver side driveshaft out and the passenger wheel didn't spin in gear and I could change gear without clutch depressed. Could a diff swap be appropriate?
