Timing Chain Cover Gasket Leak
3 replies to this topic
#1 leyland_cars
leyland_cars
    Starting My Mini Up
  • 4 posts
Posted 10 April 2018 - 11:06 PM
Hi, was wondering if anyone could help. I have an oil leak from the timing chain cover on a 1979 mini 1100 special. Original engine, I thought that oil shouldn't get past the crankshaft bearing oil seal before entering the timing chain area or is oil suppose to get in to lubricate the chain?
Hoping that's the case which will mean just a new timing chain gasket around the cover.
Regards John
#2 nicklouse
  • 18,724 posts
Posted 10 April 2018 - 11:16 PM
the timing gear is open to the engine.
#3 Spider
  • 15,201 posts
Posted 11 April 2018 - 12:50 AM
While changing it, it'snot a bad idea to do the seal while your at it and even replace the Chain & Sprockets.
On replacing the cover, they do need to be centraised before tightening down the bolts. There is a tool for doing this.
#4 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 11 April 2018 - 07:22 AM
Also, when it's off, look at all of the bolt holes. Are they pushed inwards toward the gasket face due to the tightening process ?
If they are by much, it wont seal as those high areas hit 1st and the gaps between the holes aren't pressing on the gasket
