Snapped Caliper Bleed Nipple
7 replies to this topic
#1 DUF2
DUF2
    Formally known as DUFfi
  • 456 posts
  • Local Club: Whickham & DMC
Posted 19 April 2018 - 06:56 PM
Whilst bleeding the brakes on my Elf 8.4" four pot calipers, I have snapped one of the bleed nipples, it is the one on the side of the caliper.
As these calipers have three bleed nipples can I get the air out of the remaining two bleed nipples?
I was able to get fluid out of the top nipple and do have a reasonable pedal.
Any ideas on how to remove & replace the snapped nipple?
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 19 April 2018 - 07:16 PM
no wont work with 2 nipples
wd40 it a couple of days or plus gas
flat blade screw driver just a bit bigger than the hole in the nipple a hammer it in and try twisting it out..
find out what drill size it is for the tap of a bleed nipple and get a left hand drill that size or just a bit smaller and see if it will drill out.
replace-take off the unit and then take it a machine shop get it eroded or machined out ..
mean time order a nipple you need.
#3 Dusky
Dusky
  • 5,322 posts
Posted 19 April 2018 - 08:47 PM
I'd try sticking a stick weld electrode on it and twist it out.
The heat will loosen it most of the time. Try not to damage the seat of the nipple.
#4 Homersimpson
Homersimpson
  • 829 posts
Posted 19 April 2018 - 08:50 PM
I've.bled.these.with.only.one.nipple.before.by.unbolting.the.callier.and.altering.the.angle.to.get.the.air.out.
#5 dotmatrix
dotmatrix
  • 440 posts
Posted 19 April 2018 - 09:08 PM
in my experience if you have connected two hoses to each calliper you can bleed them if you snap the inside bleed nipple, but not the top or outside. If you only have one hose to each calliper I don't know.
they tend to snap those bleed nipples, I always put copper grease on them before I put them in.
when they snap we usually weld a nut on the bleed nipple, the heat from welding normally makes it possible to screw it out.
Edited by dotmatrix, 19 April 2018 - 09:09 PM.
#6 gazza82
gazza82
  • 3,014 posts
  • Local Club: TMF+
Posted 19 April 2018 - 10:17 PM
Plus gas is far more efficient than wd40 ... but sounds like the bleed nipple has been overtightened. Reverse drill bit might also work .. with drill on reverse drive too.
#7 Ethel
  • 25,931 posts
Posted 19 April 2018 - 11:46 PM
4 pot caliper? The top nipple serves the top cylinders on both sides. As the link between the bottom cylinders is through the mating faces of the caliper halves under the pistons they need 2 nipples- one at the highest point on each side. Try and arrange your remaining nipple to be the highest point. You might have to resort to pushing the opposite piston, with the caliper upside down, to push trapped air from one side to the side where it can be expelled via the bleed passage.
If you end up drilling out the broken nipple and destroy bleed screw seat, one trick to salvage the situation is to use a ball bearing held in with a male brake union.
#8 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 20 April 2018 - 11:39 AM
Happened twice on me when I ran my metro set up couldnt take it any more so went 10 inch best decision ever
Edited by cian, 20 April 2018 - 11:40 AM.
