Painting Clubman Grille
9 replies to this topic
#1 jt19
jt19
  • 745 posts
Posted 22 April 2018 - 06:35 PM
Hi
I'm thinking of painting my clubby front grille gloss black.
What would be the best way of preparing it for paint? Rub over with wire wool and degrease? Or would would I be able to sandblast it or similar? I'm thinking not due to it being plastic! Lol
There's so many little nooks and cranys I'm not sure I'd get them all with wire wool/wet and dry.
Any advice would be appreciated
#2 nicklouse
  • 18,657 posts
Posted 22 April 2018 - 07:02 PM
clubman grill should be pressed aluminium. i polished mine up. masked off the bits i wanted shiny then preped and primed and painted the bits i wanted black then removed the tape and clear glossed the lot.
#3 jt19
jt19
  • 745 posts
Posted 22 April 2018 - 07:44 PM
Oh right I assumed it was plastic for some reason.
Would that be OK to get sandblasted then?
#4 nicklouse
  • 18,657 posts
Posted 22 April 2018 - 07:46 PM
nope.
#5 DazWood
DazWood
  • 182 posts
  • Local Club: North East Mini Club
Posted 23 April 2018 - 04:51 AM
When I did mine, I just rubbed it down with wet and dry, primed and sprayed
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,060 posts
  • Name: Neil
Posted 23 April 2018 - 11:31 AM
It’s very soft aluminium so vapour blasting is the way forward.
#7 Chris.Williams
Chris.Williams
  • 679 posts
Posted 24 April 2018 - 06:05 AM
I used a scotch bright on mine, same as others with taping off what I didn’t want painted.
Hit it with the paint.
#8 sonikk4
sonikk4
  • 16,060 posts
  • Name: Neil
Posted 24 April 2018 - 07:14 AM
I cleaned up the Ali on mine first then taped off the areas to be painted, a light scotchbright pad over the bare areas, etch prime then topcoat.
#9 jt19
jt19
  • 745 posts
Posted 24 April 2018 - 12:44 PM
OK guys that's what I was thinking.
I'm gonna paint the whole thing black so a bit easier without having to mask it up etc.
Should I use a primer before paint? Or just etch on the bare bits?
#10 sonikk4
sonikk4
  • 16,060 posts
  • Name: Neil
Posted 24 April 2018 - 07:24 PM
I used etch then black topcoat.
