Hif6 Hole Between Lower Stud Holes On Manifold Flange
4 replies to this topic
#1 hhhh
hhhh
  • 422 posts
Posted 23 April 2018 - 02:58 AM
What's it for? Won't it get blocked by the spacer and gasket?
#2 timmy850
timmy850
  • 3,400 posts
  • Local Club: MITG
Posted 23 April 2018 - 03:18 AM
The manifolds are often drilled to suit a number of different carbs. This manifold can use twin 1.5" (HS4 HIF38), 1.75" (HS6 HIF44), or H4
http://www.minispare...t/C-AEG490.aspx
The H4 carbs are 1 1/2" and have the two vertical studs
http://www.minispare...n/C-AUD178.aspx
#3 hhhh
hhhh
  • 422 posts
Posted 23 April 2018 - 04:46 AM
Sorry I guess I wasn't clear. The hole is in the flange on the carb and you can see what looks like a vertical half pipe of brass , about 1/2" down the hole. At the bottom of the carb bore is a tiny hole below wear the butterfly stops at idle, with a brass tube liner that doesn't quite line up with the half pipe in the flange face hole.
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 23 April 2018 - 08:40 AM
Pretty sure thats the passage for the cold start enrichment (choke)
#5 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 23 April 2018 - 11:35 AM
They usually have an ally bung in the hole near the face, and as you say just get blanked off with the gasket / spacer anyway
