Vibration/noise At Certain Rpm
15 replies to this topic
#1 smurfomatic
smurfomatic
  • 461 posts
Posted 29 April 2018 - 11:28 AM
Over the last few days I've noticed a strange vibration-like noise at certain rpm (roughly 2k in 3rd and 3k in 4th) - only happens when driving so difficult to see what's going on. This occurs at part throttle, ease off slightly or accelerate a little and it goes away.
Apologies for the quality of this recording, but you can hear it at roughly 10-11 seconds and 16-22 seconds:
https://drive.google...iew?usp=sharing
Any suggestions? I've tried checking if anything obvious is loose in the engine bay, but can't really think what to check next.
#2 smurfomatic
smurfomatic
  • 461 posts
Posted 29 April 2018 - 12:56 PM
A few things that may (or may not) help:
Mini Marcos, based (as far as I can tell) on a Mk 2 Mini but built in 1980
998 with HS4 carb
Remote chanage gearbox, rebuilt & new clutch from Guessworks 6 months ago
#3 Spider
  • 15,201 posts
Posted 29 April 2018 - 06:15 PM
It could be a broken engine mount.
#4 smurfomatic
smurfomatic
  • 461 posts
Posted 29 April 2018 - 06:40 PM
Thanks Moke, will investigate at some point over the next few days - if it ever stops raining here!
#5 smurfomatic
smurfomatic
  • 461 posts
Posted 30 April 2018 - 07:15 AM
Is there likely to be a steering related cause for this? Only asking as I just went to leave for work and something major has gone wrong, steering is all over the place.
There hasn't been any kind of vibration through the steering wheel so might be a coincidence.
#6 smurfomatic
smurfomatic
  • 461 posts
Posted 05 May 2018 - 10:28 AM
Only got the car back yesterday (garage couldn't source a Mk2 steering column so had to modify a newer one) but noise is still there.
Engine mounts & stabilisers look fine to me, though I did notice the manifold clamp wasn't bolted to the engine - will give it a run tomorrow and see how it sounds.
#7 smurfomatic
smurfomatic
  • 461 posts
Posted 07 May 2018 - 04:37 PM
Well, adding the bolt on the manifold clamp hasn't got rid of the noise. Does anyone have any further suggestions?
#8 Spider
  • 15,201 posts
Posted 07 May 2018 - 07:31 PM
What engine does it have and has it got any modifications?
These can be curly to work out via a keyboard and computer screen.
#9 smurfomatic
smurfomatic
  • 461 posts
Posted 07 May 2018 - 09:11 PM
It's tricky to work out from inside the car too! with it only happening at around 30mph in 3rd and 55-60mph in 4th it's a bit difficult to pin down.
Standard (as far as I can tell) 998 - possibly from a Mk2 Mini as that seems to be the age of a lot of the donor parts
Single HS4 carb (recently had a new jet, not that this should be causing the noise!)
4 synchro remote box, John at Guessworks rebuilt it in November as the case was damaged by a failed idler gear bearing
May have to take the guy from the local Mini garage for a run in it, to try and get his opinion.
#10 smurfomatic
smurfomatic
  • 461 posts
Posted 08 May 2018 - 10:32 AM
Sorry, just to add:
Clutch & flywheel replaced at same time as gearbox rebuild
New Accuspark electronic dizzy & leads about a month ago
New brake shoes all round at the same time as dizzy
#11 smurfomatic
smurfomatic
  • 461 posts
Posted 18 May 2018 - 08:30 AM
So, finally got time for the guys at the local Mini garage to take a look. Left it with them yesterday morning, they looked it over but couldn't replicate the noise. Took one of them for a drive and managed to show him what was happening. they reckon it's the idler gear, which would be a surprise as it's only six months since John at Guessworks completely rebuilt the gearbox...
#12 Spider
  • 15,201 posts
Posted 18 May 2018 - 08:58 AM
Sadly, the audio in your recording isn't the best, however I could hear something that could be an Idler Gear werring away, though, other than a noise these don't normally make a vibration.
Might be worth going to a shop who does Minis and getting another opinion.
#13 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 18 May 2018 - 09:12 AM
When you say John rebuilt the gearbox, did he set up the idler gear clearance in the transfer case as well?
#14 smurfomatic
smurfomatic
  • 461 posts
Posted 18 May 2018 - 09:14 AM
He had to move everything into a new casing as the old one was damaged, so I assume he will have set up all the clearances.
#15 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 18 May 2018 - 09:15 AM
I understand he built the box but who assembled the transfer case?
