Clip On Bulkhead Under Carb
8 replies to this topic
#1 DUF2
DUF2
    Formally known as DUFfi
  • 457 posts
  • Local Club: Whickham & DMC
Posted 30 April 2018 - 05:44 PM
What is this clip for on the bulkhead underneath the carburettor (1965 Riley Elf)
The speedo cable is close to it but seems too short to fit into the clip.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,044 posts
Posted 30 April 2018 - 06:02 PM
Clip for the fuel pipe I Think
#3 nicklouse
  • 18,730 posts
Posted 30 April 2018 - 06:05 PM
it was either the clip for the speedo cable or the fuel pipe. been a while since i thought about this one.
#4 DUF2
DUF2
  • 457 posts
Posted 30 April 2018 - 06:39 PM
Can't be for the fuel pipe as the engine has a mechanical pump and the pipe from the pump to the carb, would be better not clipped to the body.
Speedo cable seems too short to clip into this clip
#5 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 01 May 2018 - 12:30 AM
They are for the speedo cable, the idea being so it doesn't melt with the exhaust heat
#6 timmy850
timmy850
  • 3,399 posts
  • Local Club: MITG
Posted 01 May 2018 - 12:40 AM
Yes for the speedo. Part number 5L90
http://www.somerford...page=page&id=83
As far as I can find out the mechanical pumps weren't factory fitted till 1969
http://www.somerford...age=page&id=162
#7 DUF2
DUF2
  • 457 posts
Posted 01 May 2018 - 06:42 AM
Ah that figures. I should have said my car is fitted with an '89 1275 Metro engine, hence the mechanical pump. Cable seems to short to fit into clip, assuming the clip is in the correct location! It is dead centre under the carb, the cable runs around 80mm to the right (radiator side) and seems to short to fit into the clip.
#8 timmy850
timmy850
  • 3,399 posts
  • Local Club: MITG
Posted 01 May 2018 - 06:47 AM
You might have a different speedo cable to the factory one then? There were a couple of different lengths available. If it's working it's not worth removing!
http://www.minispare...eedos.aspx?0503
#9 DUF2
DUF2
  • 457 posts
Posted 01 May 2018 - 09:11 AM
I have just found this image in one of my Mini books, which shows the speedo cable in the clip.
I suppose I should have checked there first!
