Hi, I have a cam for the engine I'm building - I always thought it was a Kent 276 - but now I'm not so sure. It has "276" engraved, but looks like a regrind from an original cam. (1 raised ring between lobe 5&6)
Lift is 7.4mm on the exhaust and 7.7 on the inlet - but i do not know the seperation angle, timing, nor the full lift angle.
..So what do I aim for when setting it up? 106 deg like the KentCams 276? Or do i fit a dial gauge on the cam once in the engine (no head or pushrods fitted, so I can spin it freely) and then start measuring? (What lift is the duration on the KentCam measured, and is it cam lift or valve lift that is used?)
