Wheel Arch Screws
11 replies to this topic
#1 MikeJE
MikeJE
  • Just Joined
  • 134 posts
  • Local Club: LSMO
Posted 04 May 2018 - 02:11 PM
The wheel arches on my black mini 30 are held on with 10x1/2 in screws rather than rivets. The problem is that the normal self-tapping screws I can find have such large heads that they do not fit into the cut-away properly and as a result force the arch to twist out. I am having trouble finding self-tapping screws with small heads and wondered if anyone on the forum knew of a source, please. It doesn't matter if they are black or silver as I can paint them...
All best wishes and thanks in advance
Mike
#2 TheFabMini
TheFabMini
  • 459 posts
Posted 04 May 2018 - 05:54 PM
I used self tapping screws with a head size I liked and put spire clips the other side. Worked for me!
#3 Cooperman
  • 23,340 posts
Posted 04 May 2018 - 06:14 PM
I use M4 Rivnuts and stainless steel M4 socket head cap screws.
#4 MikeJE
MikeJE
  • Just Joined
  • 134 posts
  • Local Club: LSMO
Posted 05 May 2018 - 10:05 AM
Good ideas, thanks. I had never heard of rivnuts! I suppose an alternative is to use screws with locking nuts behind the wing.
Many thanks for responding. Much appreciated
Best wishes
Mike
#5 Cooperman
  • 23,340 posts
Posted 05 May 2018 - 10:43 AM
You can buy the Rivnuts and fitting tool from Namrick together with the stainless steel M4 socket head cap screws and small stainless washers.
No more rust so long as you put a bit of grease on the Rivnuts and the screws always look good and are easy to tighten and remove.
#6 MikeJE
MikeJE
  • Just Joined
  • 134 posts
  • Local Club: LSMO
Posted 05 May 2018 - 09:19 PM
That’s brilliant, thanks. May I impose further on your kindness and ask what size and type of Rivnut I need. The Namrick website has a dizzying array of types and sizes of M4 rivnuts and it would be really helpful to know what to order.
With best wishes
Mike
#7 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 05 May 2018 - 11:05 PM
With best wishes
Mike
Cooperman suggested M4 rivet nuts, the .25 to 3.0 mm Namrick lists should be fine for the fender sheetmetal. You'll need the install tool too. Like this https://www.workshop...-riveter/AK393/
You could also look at http://www.memfast.co.uk/ for tooling and rivet nuts. I can't regularly get metric stainless rivet nuts we use in the bicycle shop in the US so I usually get them from the UK you guys have multiple sources.
Edited by bikewiz, 05 May 2018 - 11:11 PM.
#8 G'Racy
G'Racy
  • 174 posts
Posted 04 February 2019 - 02:13 PM
Read quite a few threads on here on the merits of using stainless steel rivnuts in a mild steel panel, understand door mirrors are fixed using rivnuts, as a matter of interest anyone tell me what material these rivnuts are?
Trying to decide whether to use screws, rivets or rivnuts, what have you used and what material?
#9 nicklouse
  • 18,724 posts
Posted 04 February 2019 - 02:30 PM
don't use stainless.
use mild steel or aluminum.
#10 Bobbins
Bobbins
  • 1,525 posts
Posted 04 February 2019 - 04:39 PM
Aluminium rivnuts are the easiest to "set" and will do the job fine, if you then use stainless steel button head screws use plenty of Alumslip on the threads to prevent seizing. It's worth investing in a good tool and a variety of sizes of rivnuts because you'll find loads of other uses for them ... mounting the grill being just one.
#11 G'Racy
G'Racy
  • 174 posts
Posted 04 February 2019 - 05:55 PM
I should have said I’m initially using these to fit some Huddersfield group 2 arches in place of the standard arches that are presently riveted on.
#12 RaulSims
RaulSims
  • 92 posts
Posted 14 June 2019 - 11:33 AM
Over a painted surface? How did that go? Any cracking on the paint?
