Oil Pressure Switch Connection
26 replies to this topic
#1 jonlad
jonlad
  • 325 posts
Posted 06 May 2018 - 06:45 AM
Hello
I've replaced my single connection oil pressure switch for a minispares one which has two spade connections on it and operates at higher pressure...
I'd like to lash up a test lamp so that I can spin over the newly rebuilt engine on the bench and test for oil pressure.
So, how do these work and do both connections do the same job?
Are they a link to earth (the block) that opens when pressure is reached?
Many thanks
Jon
#2 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 06 May 2018 - 09:53 AM
If spinning up for the first time I would use a mechanical pressure gauge.
#3 jonlad
jonlad
  • 325 posts
Posted 06 May 2018 - 10:42 AM
Thanks, any reason why?
Original questions still stand if anybody knows the answer?
#4 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 06 May 2018 - 10:50 AM
The one you've linked is a warning lamp sender. All it does it illuminate the warning lamp if you have less than 20psi. It won't tell you the actual pressure reading (which can also be too high if you have some problems). I don't know why it has two terminals though
A mechanical one is very simple to install and requires no wiring to make it work. It also never has a problem with the wrong sending unit or voltage.
#5 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 06 May 2018 - 11:49 AM
A) if your wiring is dodgy you may not know until too late
B) you want to know the exact pressure not just >20. You also need to know if it's too high.
You can swap it out and put the sender back later ... or fit a t-piece and have both for piece of mind
Edited by gazza82, 06 May 2018 - 11:50 AM.
#6 rww
rww
  • 150 posts
Posted 06 May 2018 - 11:56 AM
The 20 lb Minispares switch is exactly that. The electrical connections, spade terminals 1 & 2 , are connected when engine oil pressure is below 20lbs and disconnected when engine oil pressure exceeds 20lbs. One spade terminal should be connected to a local earth and the other to the (existing) warning lamp and battery.
This will, at the least, indicate your new engine has oil pressure but not how much. For your own peace of mind it is well worth having a mechanical oil pressure guage as well.
#7 jonlad
jonlad
  • 325 posts
Posted 06 May 2018 - 02:04 PM
That's what I was wondering, thanks.
Cheers   :highfive:
Thanks gazza, makes sense now :)  and extra question for bonus points is what pressure should i be looking for with a 1275 with new pump?
#8 nicklouse
  • 18,689 posts
Posted 06 May 2018 - 02:06 PM
you can get a gauge that screws directly into the block. great for checking what is actually going on. one of the best bits of kit i have.
#9 nicklouse
  • 18,689 posts
Posted 06 May 2018 - 04:05 PM
Attached File  image.jpeg   39.04K   3 downloadsAttached File  image.jpeg   37.47K   1 downloads
That's what I use on first starts.
#10 jonlad
jonlad
  • 325 posts
Posted 06 May 2018 - 07:31 PM
​great idea, thanks nicklouse, those little gauges are quite cheap. What pressure am I looking for when turning over on starter?
Thanks again
#11 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 06 May 2018 - 07:47 PM
Thanks again
40 psi on the starter,
About 60 psi once running, anything higher than 75 needs investigation
Edited by cal844, 06 May 2018 - 07:48 PM.
#12 jonlad
jonlad
  • 325 posts
Posted 20 May 2018 - 08:53 AM
Coming back to this thread now I have a gauge...
Spinning on the starter is giving me 80psi. Engine is rebuilt 1275 with minispares GLP138 'standard' pump.
Going by your figures this is high, is this due to everything being new or have I done something wrong? Wondering how accurate the £4 Chinese gauge is...
Thanks all
Jon
Edited by jonlad, 20 May 2018 - 08:54 AM.
#13 nicklouse
  • 18,689 posts
Posted 20 May 2018 - 12:52 PM
i would be happy with that to start it up.
#14 jonlad
jonlad
  • 325 posts
Posted 20 May 2018 - 06:14 PM
Thanks Nicklouse, I appreciate the advice!
#15 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 20 May 2018 - 06:24 PM
That's a good pressure, especially on the starter
