Cross Pin Diff Sloppy
10 replies to this topic
#1 Kemo
Kemo
  • 14 posts
Posted 20 May 2018 - 06:55 AM
Morning all, Ive had a quick search and not really found the answer is was after, I recently bought a x-pin from Guessworks lovely bit of kit, and I assembled and torqued it up yesterday all looks good spins freely, but if I grab the housing in the vice, and grab either output shaft theres a small amount of up/down side to side movement is this normal of is my diff too sloppy maybe I need thicker thrust fibres?
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 20 May 2018 - 07:50 AM
Can you measure the sloppyness? Using a dial gauge for example? Or post a video? There has to be a small movement to ensure sufficient oil clearance.
Ac
Edited by ACDodd, 20 May 2018 - 07:51 AM.
#3 Kemo
Kemo
  • 14 posts
Posted 20 May 2018 - 05:01 PM
Yeah I can get a video or measure it tomorrow when Im back at the yard
#4 Kemo
Kemo
  • 14 posts
Posted 21 May 2018 - 07:49 PM
https://youtu.be/bRZCGBSld9Y Can someone please have a watch and give me your opinion....
#5 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 21 May 2018 - 08:02 PM
To much slop for me there, with a pot joint on that it will be greatly exaggerated
#6 Kemo
Kemo
  • 14 posts
Posted 21 May 2018 - 08:10 PM
My thoughts exactly! Any advice suggestions mate?
#7 Spider
  • 15,142 posts
Posted 21 May 2018 - 08:39 PM
Should be better than that.
#8 imack
imack
  • 2,205 posts
Posted 21 May 2018 - 08:40 PM
I don't know what the tolerances should be, nothing in the haynes manual?
What sort of condition were your output shaft bearing surfaces in?
Don't forget that the output shaft will also be supported by the pot joint in the gearbox side plate bushes once fully assembled.
#9 Kemo
Kemo
  • 14 posts
Posted 21 May 2018 - 08:48 PM
The faces looked ok on the output shafts but then Ive never hid one apart before..... but its all new besides them wonder if its worth just replacing them?
#10 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 21 May 2018 - 09:32 PM
You likely need a new crown wheel bush fitting. It's then needs to be machined to fit your output shaft.
Ac
Edited by ACDodd, 21 May 2018 - 09:33 PM.
#11 cian
cian
  • 869 posts
Posted 22 May 2018 - 02:47 AM
Strip down and try a new fibre washer and see if that helps any
