Halogen Replacement For Sealed Beam
11 replies to this topic
#1 MMM1965
MMM1965
  • 93 posts
Posted 20 May 2018 - 03:54 PM
Hi i was wondering if anyone could help please? One of the lucas sealed beam units has given up the ghost after many years service on my 1965 mini minor. I am contemplating replacing both units with halogen but am concerned the ancient wiring and switch wont cope. Any advice gratefully received. Thanks
#2 CityEPete
CityEPete
  • 3,920 posts
Posted 20 May 2018 - 04:46 PM
I'd swap them both for halogen and fit a relay kit, it's easy enough to do and the new brighter lights will then actually take no load off the old switches/wiring.
#3 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 20 May 2018 - 04:48 PM
Basically what he said. :lol:  Wired By Wilson can provide you with a 'plug n play' loom for relays. :highfive:
#4 Ethel
  • 26,144 posts
Posted 20 May 2018 - 04:50 PM
Good advice from Pete, though the halogens won't create any axtra load  provided the bulbs are rated the same as the sealed beams.
#5 ukcooper
ukcooper
  • 1,625 posts
Posted 20 May 2018 - 04:58 PM
as ya have to swop the hole units , get the mot station line em up after and a 5 min chat to get to know em and get in there good books
wiring by will son highly recommended -- http://www.theminifo...d-new-releases/
#6 CityEPete
CityEPete
  • 3,920 posts
Posted 20 May 2018 - 05:35 PM
Well he's only got one at the moment, lol
#7 cal844
cal844
  • 9,667 posts
  • Local Club: TFMOC
Posted 20 May 2018 - 06:26 PM
My 1980 estate has the halogen kits fitted, the wiring is still standard on all 3 of our minis(one still to be converted).
You don't necessarily need a relay kit, I just carry a spare switch in the tool bag
#8 andyapanel
andyapanel
  • 627 posts
Posted 21 May 2018 - 07:40 AM
Yes, you CAN just swap the lights, but sooner or later the lighting switch will fail. I used to carry Minispares replacement looms and spare light switches till I installed a WIRED BY WILSON kit It deals with the problem, tho it does remove that adrenaline rush when your lights disappear in the dark.
I would fit it at the same time as you install the new lights.
Good luck
#9 miniireland
miniireland
  • 175 posts
Posted 21 May 2018 - 12:59 PM
I used to run 130/90 bulbs in my cars with Valeo/Cibie headlamp replacement units, never had a wire burn out on a loom or switch
#10 Cooperman
  • 23,357 posts
Posted 21 May 2018 - 01:45 PM
In terms of the actual light units, there are several available.
Wipac are OK whilst Cibie or Hella are the best.
Autopal are also quite good.
#11 dangerousdowning
dangerousdowning
  • 191 posts
Posted 13 December 2018 - 06:19 PM
Just digging up this thread - I was planning to convert my sealed beams to halogen at some point, but now the bulb has just gone in one of my headlamps (1989 Mayfair), so makes sense to do it now.
Moss Twickenham branch is fairly local. So any recommendations to what they have:
https://www.moss-eur...conversion.html
Also, will they fit to the existing headlamp bowl I have fitted or do I need to modify or replace any parts?
Would these all require a relay?
#12 cal844
cal844
  • 9,667 posts
  • Local Club: TFMOC
Posted 13 December 2018 - 09:09 PM
I'd advise you to fit a headlamp relay kit from Wired by Wilson (you won't really need it but best to be safe)
The halogen kit will be plug and play with only the sidelight wires to be cut and reterminal'd.
I can't comment on the wiring changes needed to fit the relay kits as I haven't fitted one (I have fitted multiple halogen conversions)
