Hello, I have a 95 fuel injected mini, and the o2 sensor has a Wire coming through the floor pan as you'd expect. But then it ends and I can't find the two wires (red and white) wires that have been severed from it. In other words I can't find the routing for where the wire is meant to go.
I'm assuming it goes to the ECU but I don't know which pin goes to that circuit. So if anyone would happen to know what pins in the ECU go to the 02 sensor that would also be handy, so I can connect them with a new wire.
1 reply to this topic
![]() 1986 Mini Chelsea - Main Beam IssueStarted by Dominic1998 , 25 Apr 2025 ![]() |
Mini Technical Sections →
Problems, Questions and Technical →
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
