Hi,
My mini 1975 clubman just failed MOT on back brakes.
With an assistant pressing the brake pedal I can just manage rotate the back wheels (with great effort).
I checked the rear shoes and they are OK
I checked the pistons in the rear cylinders and they all move freely.
So initially it seems like either there is a partial blockage or the pressure limiter valve is the culprit?
However... both wheels brake in exactly the same way with equal force needed to turn the wheels, so if its a blockage then it would suggest that the fault is in a common component.
But the brakes are single circuit and the only common pipe is BEFORE the limiter valve.
Secondly I would expect that if the limiter valve were leaking internally (piston seals gone) then the braking would be too great not weak?
Does anyone know:-
What pressure does the brake limiter shut off the rear braking at?
One should be able to fit a pressure gauge in one of the bleed nipple outlets and measure it?
How can one test the brake limiter valve?
Anyone had a similar problem and found the solution?
Please enlighten me...thanks in anticipation
Dave
