Thermo Switch 85-95 (95 On - 85 Off) 1/8 Npt
12 replies to this topic
#1 nicklouse
  • 18,696 posts
Posted 29 May 2018 - 11:15 PM
any one know of a OE part number for one of the above, all the part numbers i find do not state that they are a switch or just a sensor i am thinking GM does one so can check later but if any one know of one....
#2 Spider
  • 15,136 posts
Posted 30 May 2018 - 03:02 AM
Nick,
I've just looked though around 100 of them, the only imperial threads I could find were 1/8" and 3/8" Gas threads, the others were Metric. It appears that 1/8" NPT for these is 'odd-ball'.
Are you locked in to 1/8" NPT?
I'd suggest if a change is possible to consider Metric and there's a huge range available.
#3 nicklouse
  • 18,696 posts
Posted 30 May 2018 - 07:28 AM
have drill and Tap so anything is possible, that is what was in the part.
#4 Spider
  • 15,136 posts
Posted 30 May 2018 - 08:10 AM
Next issue is finding one one with a 100 differential !!
There are a few, but I think this one fits your ticket and has a second higher temp, switch
http://www.tridon.co...ches/333/TFS208
#5 nicklouse
  • 18,696 posts
Posted 30 May 2018 - 11:36 AM
mm I think I will be sitting down with the local auto stores catalogues after seeing what the max hole I can put in this is. mm 16mm tapset anyone?
#6 Icey
Icey
  • 1,553 posts
Posted 30 May 2018 - 11:57 AM
Most I found were M22 which is good as that's what's in my rad!
You can get surface mount ones as well if you don't want/don't have a tapped hole.
eBay is your friend though, bucket loads on there of all the flavours.
#7 nicklouse
  • 18,696 posts
Posted 30 May 2018 - 12:03 PM
sure there are loads on Ebay but this is the type of think I like to have in hand, but I am thinking of turning the housing I have into a temp switch and drain plug housing.
#8 smurfomatic
smurfomatic
  • 461 posts
Posted 30 May 2018 - 12:04 PM
Some rad thermostats are M14 like the ones that fit in the Fletcher rad. Mahle do a range (TSW) that have 5 degree increments so you can probably find one that suits.
#9 nicklouse
  • 18,696 posts
Posted 30 May 2018 - 10:21 PM
ok what i have currently decided on is to use this for two functions. the current hole will be a drain and the flat side opposite will take a Metric fitting thermo switch.#
#10 nicklouse
  • 18,696 posts
Posted 08 June 2018 - 10:37 PM
well this has been a bit of a fuss.
this lot arrived on thursday
then today i had to get
 but thats two taps i hear you say. yep the first one was undersize by about 0.25mm and the Sump plug is well the drain plug will be the same thread as the sensor was a little to far back in the housing
will be fine as a drain
just need to drill and tap a new hole as fit
oh VW sump plug
#11 Spider
  • 15,136 posts
Posted 09 June 2018 - 12:27 AM
Nice work Nick. I wouldn't worry too much about the switch being recessed in a bit, the fitting, being all aluminum will quickly follow the coolant temp with little lag.
#12 nicklouse
  • 18,696 posts
Posted 09 June 2018 - 12:42 AM
true, but still going to add another hole on the otherside for the sensor. and use the current as a drain as it will be the lowest point in the cooling system. also i get to use the expensive tap for a second time.
#13 nicklouse
  • 18,696 posts
Posted 09 June 2018 - 08:25 PM
bad tap
good tap
fitted. not fasten up
wiring done and comes on with thermo switch and can also be manually switched.
just need tidying.
