Kpa At Idle
17 replies to this topic
#1 germini30
germini30
  • 699 posts
Posted 01 June 2018 - 05:59 PM
Anyone know what kpa you should have in the inlet manifold at idle.
#2 mini13
mini13
  • 3,811 posts
Posted 01 June 2018 - 06:09 PM
Depends a lot on the cam, but 40-55 kpa probably covers it
#3 germini30
germini30
  • 699 posts
Posted 01 June 2018 - 06:19 PM
I have an mg metro cam and mine is sticking at 34kpa
#4 paul748
paul748
  • Just Joined
  • 80 posts
Posted 01 June 2018 - 06:46 PM
This is so weird!
I have just replied to exactly the same question on another (MINI) forum, but for the R53 cooper S.
I know it's not relevant but it's the same …..42 kpa.
#5 germini30
germini30
  • 699 posts
Posted 01 June 2018 - 06:48 PM
Mine is 34 kpa. What does that mean
#6 Spider
  • 15,233 posts
Posted 01 June 2018 - 07:30 PM
Just to be clear, is this Manifold Vacuum?
#7 germini30
germini30
  • 699 posts
Posted 01 June 2018 - 07:34 PM
Yes
#8 Spider
  • 15,233 posts
Posted 01 June 2018 - 07:43 PM
Yes
OK cheers.
So in numbers I can understand, that's just a whisker over 10" mg Vacuum.
Where are you measuring this at? Direct off the Manifold or from a Port on the Carb?
#9 germini30
germini30
  • 699 posts
Posted 01 June 2018 - 08:19 PM
This is what my megajolt is saying the kpa is at the inlet manifold
#10 Spider
  • 15,233 posts
Posted 01 June 2018 - 08:29 PM
Is it calibrated to measure absolute pressure or pressure from atmospheric pressure?
Also, have you check it with a separate known gauge?
#11 germini30
germini30
  • 699 posts
Posted 01 June 2018 - 09:34 PM
I have no idea sorry. It has a vacuum pipe from the unit itself to the inlet manifold.
#12 mini13
mini13
  • 3,811 posts
Posted 01 June 2018 - 09:50 PM
34 is lower than I would have thought, but not out of the realms of possibility, certainly I have heard of high CR short cammed engine that pull similar,
Just to clarify. 0 kpa is an absolute vacuum, 101.3 kpa is atmospheric pressure at sea-level,
#13 RooBoonix
RooBoonix
  • 1,225 posts
Posted 01 June 2018 - 10:51 PM
Usual vacuum at idle on an SPI is around 30kpa I believe and I normally get between 30 and 34kpa measured by my ECU.
Just for reference.
Cam.
#14 germini30
germini30
  • 699 posts
Posted 02 June 2018 - 07:30 AM
Thanks so I am about right
#15 mini13
mini13
  • 3,811 posts
Posted 02 June 2018 - 09:31 AM
Yep, bigger cams with more overlap will make less vacuum (higher kpa) on full race stuff with itbs I've heard of idle figures in the 60s-70s,
A method of tuning idle advance is to tune it for the lowest kpa, but it sounds like your right in the ballpark anyway.
