What Needle And Jet
5 replies to this topic
#1 Xfitcarper78
Xfitcarper78
    Just On Tickover
  • 7 posts
Posted 02 June 2018 - 12:23 AM
Hi everyone
Is it possible any body could tell me what needle and jet I should be using on my 998 cc with a hif 38
With engine number 99h f16 b 100886 any help would be appreciated
Thanks Ben
#2 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 02 June 2018 - 09:29 AM
The jet is a standard size for the carb, it's only the needle you need to change to give the correct fuelling. AAC is the stock 998 needle iirc.
Phil.
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 02 June 2018 - 01:00 PM
get it running I use a aaa then get it rolling roaded...aaa is about as rich as they come I think
#4 carbon
carbon
  • 2,590 posts
Posted 02 June 2018 - 02:53 PM
Ben, if your engine is standard then use the factory recommended standard needle for your year and model.
As Turbo Phil says, the jet is a standard size, the needles are changed to meet the engine's fuelling requirements.
For the HIF38 the main jet is 90 thou size.
#5 cal844
cal844
  • 9,633 posts
  • Local Club: TFMOC
Posted 02 June 2018 - 03:38 PM
For a 998 with stage one kit(HS4 carb) I use AAU needle but would be a good start point with a HIF 38
#6 Xfitcarper78
Xfitcarper78
    Just On Tickover
  • 7 posts
Posted 03 June 2018 - 07:19 PM
Reply thanks every one the hif was second hand am rebuilding so will replace with aac ??
