Hi there.
Recently i installed a brand new MED 7 port cylinder head onto my 1380cc motor. Head was installed with ARP studs and is running minispares roller tip rockers.
The motor was built about 4 years ago with occasional use on weekends etc, so i consider the motor to still be quite fresh.
After installing the head and getting it running, the engine started to blow white smoke. On further investigation all 4 cylinders had a considerable amount of oil in them (even amount of oil in the 4)
Ive since changed the head gasket and valve stem seals. Also a machine shop had a quick look and tested the valve seats and stems, both being fine. But the same issue persists.
Just wondering if anyone has had any issues like this with the 7 ports or has any theory's as to how the oil is getting in the cylinders.
Cheers, Tom
