Will There Be A Noticeable Ride Improvement Going From 165/60 R12 To 165/70 R10?
suspension
18 replies to this topic
#1 joekenton
joekenton
  • Just Joined
  • 39 posts
Posted 19 June 2018 - 12:55 PM
Hi,
I currently have 165/60 R12 on my 12 inch wheels, I'm thinking of purchasing the MiniSport 12 to 10 inch conversion kit and fitting 10 inch wheels, mostly for the old-skool look but also to hopefully improve the ride a bit.
I know a Mini is never going to have a modern car ride, but I've read that going to 10 inch from 12 improves ride.
If my chosen 165/70 R10 Yokohama tyres are not the best for ride, can someone suggest a tyre which would result in noticeable improvement?
Thanks!
#2 unburntfuelinthemorning
  • 1,983 posts
Posted 19 June 2018 - 01:57 PM
You might find this thread useful:
http://www.theminifo...e-ride-comfort/
#3 ace01
ace01
  • 457 posts
Posted 19 June 2018 - 04:18 PM
I certainly noticed a difference when I went from 12 to 10.  I put it down to the extra sidewall giving more flex.  My Mk1 has a lovely ride on 10s with 145 tyres.  The later mini is not quite as smooth; but close.
#4 joekenton
joekenton
  • Just Joined
  • 39 posts
Posted 19 June 2018 - 05:37 PM
145 full profile tyres?
EDIT: Also - to anyone who can answer: I have some old Dunlop 21A2744 wheels laying around which need a re-spray, they're '3.5Bx10x24' according to the markings. Would these be fine with Yokohama 165/70 R10 tyres?
Apologies for my nooby-ness
Edited by joekenton, 19 June 2018 - 05:40 PM.
#5 Minigman
Minigman
  • 779 posts
Posted 19 June 2018 - 06:00 PM
165s on 3.5” rim is a bit big. 145s would be better on those steels.
#6 Minigman
Minigman
  • 779 posts
Posted 19 June 2018 - 06:02 PM
Also need to check those drum offset steels will clear the disc calipers.
#7 absx2
absx2
  • 912 posts
Posted 19 June 2018 - 06:14 PM
As ace01 says above, minis ride the best on 145 tyres and 10" wheels.
Its a bad idea to use 165 tyres on a 3.5" rim as they will roll around on the rim and I doubt anyone would fit them for you anyway.
As Minigman has said, you need to check caliper clearance on 10" steels as some clear and some don`t. There are 2 offsets, one for full wheel trims and the other for small hub caps. The difference is about 3mm .
Tyre choice depends on many things. Do you want to go around corners really fast, do you need wet weather grip etc etc ?
#8 imack
imack
  • 2,110 posts
Posted 19 June 2018 - 07:14 PM
My friend fitted 165/70x10 to 3.5" rims back in the 80's, it wobbled like a jelly when you rocked it!!!
#9 joekenton
joekenton
  • Just Joined
  • 39 posts
Posted 19 June 2018 - 07:58 PM
Ok so I think I will attempt to restore the steel 10 inch wheels as a project and get myself some new Dunlop D1 (5x10) replicas from MiniSport. What's gonna be the best tyre for ride that I can fit on those? Would 145's fit?
I don't need anything special from my tyres, it's the ride improvement I care the most about. Hoping that all new rubber cones and 10 inch wheels will improve it enough.
Edited by joekenton, 19 June 2018 - 08:02 PM.
#10 Cooperman
  • 23,285 posts
Posted 19 June 2018 - 08:27 PM
On a 5" wheel a 165 section would be best.
My choice would be an original ST-replica Minilite at 4.5" x 10".
You can fit a 145/80 x 10 tyre and that will make the car feel like an original Cooper 'S' and you won't need wheel arch extensions which can only be a further advantage.
#11 absx2
absx2
  • 912 posts
Posted 19 June 2018 - 08:47 PM
I have just gone through a set of 145 Marshal tyres on LP918 reverse rims. I use the car all weather conditions and found the tyres to be good all rounders.
I really did not get on with Falken 145`s as I found them terrible in the wet.
Camac`s are trailer tyres in my eyes and the stiff side wall is not what you need for comfort, the balancing took a while and they spun like fifty pence pieces.
Dunlops I found to be great after an initial bed in but at nearly a hundred pounds each they are more for period restorations.
Either way you will be looking for tyre with a pliable sidewall which kind of rules out 165 tyres as they are more performance based
#12 joekenton
joekenton
  • Just Joined
  • 39 posts
Posted 19 June 2018 - 10:31 PM
My current tyres are 165/60 R12 and I have no arches at all and they don't stick out, so I'm not worried about having 165/70/ R10.
The only downside of getting 145's is none of the wheel options I prefer are available as 4.5" or lower :(
EDIT: Can anyone identify the wheel and tyre combo used here: http://3.bp.blogspot...985818229_n.jpg
Edited by joekenton, 19 June 2018 - 10:49 PM.
#13 imack
imack
  • 2,110 posts
Posted 20 June 2018 - 04:15 AM
They're a 4.5 x 10 rose petal designed to fit without arches, various companies sell their own versions of them, all the same width and all designed to fit without arches. Minispares sell a nice one. Tyres are yokohama A032r.
#14 joekenton
joekenton
  • Just Joined
  • 39 posts
Posted 22 June 2018 - 12:34 AM
Thanks for the help so far everyone.
Just one last question: If I go for 5x10 wheels and 165/70 tyres, are these going to be wider than the body of the car? (I have no arches)
#15 imack
imack
  • 2,110 posts
Posted 22 June 2018 - 04:25 AM
They probably will protrude beyond the body if you've got disc brakes, you might get away with it if you're on drums.
It's all dependant on wheel offset.
I had 5x10 compomotive tf'f on my archless mini in the 80's, they didn't protrude at the time as I was still on drum brakes but as soon as I swapped to discs the wheels protruded and I used to get pulled by the old bill on a regular basis and warned about the wheels sticking out. Still took quite a few tugs before I filled arches though.
Also tagged with one or more of these keywords: suspension
