1275 Road Use Build
4 replies to this topic
#1 WillCarter
WillCarter
  • 523 posts
Posted 21 June 2018 - 08:59 PM
Hi,
So I've 'just about' bought a 1275 A+ block, all I need to do is pay for it now. I'm going to be building the engine over quite a long time, a couple of years at least. This means that money shouldn't be a problem. So what have people done to their 1275 engines and what parts would you recommend buying? The engine will only be used on the road so I don't need a crazy rebore or 8 port head for instance. Just fairly standard parts with a few upgraded goodies to get a bit more poke out of it.
The engine will be put into a mini that itself will be getting a complete makeover, so suggestions on what to do for other parts of the car would be appreciated too.
Looking forward to your ideas and suggestions,
Cheers,
Will
Edited by WillCarter, 21 June 2018 - 09:00 PM.
#2 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 21 June 2018 - 09:30 PM
Next size of rebore(usually +20 thou)
Either a Kent 266 or SW5 cam
The most gains will be in the head port and valve work. Someone more experienced will be along soon to comment on the best sizes
You will probably need a 3.44 diff(match it to the cam)
Use good quality gaskets and seals
#3 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 21 June 2018 - 09:32 PM
A 1293 (+020") is a good size for the road, but £ 4 £ there is no substitute for cc so consider going bigger.
The next main priortiy has to be a modifed 12g940 head with 35/29 MG sized valves, worked for the road (not big ports)
A mild cam 266 to 274 duration, compression no more than 10:1
Hif 44 carb on MG metro manifold
An LCB exhaust with an RC40 system
A standard gearbox with a 3.44 or 3.76 diff
There are quite a lot of things that can be done to improve the efficiency without a huge budget, especially if you are willing to take advice and do some yourself
As to the car it self have a look at Petrol Petes thread, its the best.
http://www.theminifo...d-bolt-rebuild/
#4 WillCarter
WillCarter
  • 523 posts
Posted 21 June 2018 - 09:35 PM
Thank you both! That's a big help to start with
#5 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 21 June 2018 - 09:46 PM
If you read Pete's thread that will keep you occupied for days...hahah
No seriously if you take notice of him you will have a seriously good car, he has been the guinea pig on a complete car build and had so much hassle with bad parts ect learn from his words, it will save you a fortune in time and money.
