Vac Gauge T Piece
5 replies to this topic
#1 Ol timer
Ol timer
  • 329 posts
Posted 25 June 2018 - 07:08 PM
I am looking at putting a vac gauge in my 73 mini and I am struggling to find a T piece that is suitable to splice into the vac line from the dizzy to the manifold. Can anyone point me in the right direction.
#2 Dannyboolahlah
Dannyboolahlah
  • 168 posts
Posted 25 June 2018 - 07:27 PM
I got some 3mm vacuum hose from Halfords, slipped half an inch over the ends of the T, and push the smaller hard pipe into that.
#3 Spider
  • 14,951 posts
Posted 25 June 2018 - 07:48 PM
You can plumb the gauge in to that line, however, it doesn't properly represent Manifold Vacuum and it's Ported (or should be) from the Carb, so, depending on the particular Carb you have, at Idle, you'll find the gauge will show low or no Vacuum.
Best to come off one of the Ports (that maybe plugged up) on the Manifold or if it has non, remove the Manifold, drill & tap one in to it.
#4 Dannyboolahlah
Dannyboolahlah
  • 168 posts
Posted 25 June 2018 - 07:49 PM
Good point. Forgot about that, mine isn’t ported.
#5 Mervyn
Mervyn
  • 256 posts
Posted 25 June 2018 - 08:03 PM
Pet shop that sells fish tank bits will sell little T pieces
Merv
#6 pusb
pusb
  • 1,216 posts
Posted 25 June 2018 - 08:11 PM
I used one of these, worked great
