Indicator Fuse Blowing
2 replies to this topic
#1 kyrans
kyrans
    Starting My Mini Up
  • 1 posts
Posted 26 June 2018 - 04:45 PM
1983 austin mini 1000
Hey,
Top fuse keeps blowing when i try to use my indicators and such.
Im using a 30A 230v fuse, is this actually the right one?
If yes where should i start looking? (first mini and not great on electrical issues)
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 26 June 2018 - 06:50 PM
be ya front indicators bulb holder more than probly rusted away check and buy some blew ones ...
#3 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 26 June 2018 - 08:22 PM
Use 12v automotive fuses(they're clear glass)
I'd disconnect all output circuits(indicators, heater etc) for that fuse. Then connect each circuit in turn, when the fuse blows disconnect that circuit.
For example you connect the reverse light then indicators, which then blows the fuse.. you'd then reconnect the reverse lights and then disconnect ALL indicators at the lights...
Fit a new fuse, does it blow? If not you've found the circuit with the fault.. now connect the indicators one by one waiting a couple of minutes to see if it blows.
Once you've found the fault you now need to clean earth's or love connections as needed
