Engine Rebuild
9 replies to this topic
#1 roy1964
roy1964
  • 58 posts
Posted 26 June 2018 - 09:31 PM
Hi, when rebuilding a engine should you use gasket sealant on every gasket (apart from head gasket) or are some gaskets used dry. Any suggestions for which product to use if that the case.
#2 Wiggy
Wiggy
  • 1,036 posts
Posted 26 June 2018 - 11:14 PM
The gasket between the block/Gearbox and the transfer case should NOT have any sealant. Very important it goes on dry.
On the others, some people use grease, some blue Hylomar, some other stuff.
I used a thin smear of Hylomar. Seems OK.
#3 nicklouse
  • 18,697 posts
Posted 27 June 2018 - 12:27 AM
why? i have always used Blue Hylomar on them. never had any issues or leaks.
#4 Spider
  • 15,142 posts
Posted 27 June 2018 - 02:32 AM
I use Permatex / Loctite No.3 on all gaskets, except for;-
Head Gasket - usually dry, but depending on what it is, I may use Blue Spray on Hylomar
Cork Rocker Cover Gasket - dry
Water Pump, Thermostat Cover, Heater Take Off - RTV
#5 roy1964
roy1964
  • 58 posts
Posted 27 June 2018 - 07:21 AM
Thanks Moke Spider
#6 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 27 June 2018 - 11:23 AM
As Moke says ?
#7 Wiggy
Wiggy
  • 1,036 posts
Posted 28 June 2018 - 12:13 AM
Because I don't think you can reliably measure the idler end float if you have sealant on the gasket. There's no real reason to to do it. The gasket seals perfectly ok dry.
#8 nicklouse
  • 18,697 posts
Posted 28 June 2018 - 12:22 AM
will have zero effect on endfloat.
#9 Wiggy
Wiggy
  • 1,036 posts
Posted 28 June 2018 - 12:44 AM
How come?
#10 Spider
  • 15,142 posts
Posted 28 June 2018 - 01:19 AM
How come?
It may do and theoretically, you may have a point, however, you'd need very very expensive and 'fine' measuring gear costing all of your children + the wife to be able to sensibly measure it.
