Gear Stick Rattle / Vibration
5 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 June 2018 - 05:12 PM
Maybe not an issue, but my i can hear and feel my gear stick shaking/vibrating while in gear and driving.
Is this a problem?
#2 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 28 June 2018 - 08:34 PM
Not really as they do vibrate, are you sure it's your stick and not the heater or dash?
#3 timmy850
timmy850
  • 3,385 posts
  • Local Club: MITG
Posted 29 June 2018 - 02:46 AM
You can double check the rubber mounts are all in good condition on the gearchange mechanism.
The remote change levers have small "anti rattle plungers" which are tensioned with small springs. If they wear out they can cause rattling. They also have a spring on the pivot point
For a rod change, possibly one of these would hold a bit of tension on the lever and reduce some rattles?
http://www.minispare...ssic/MSG12.aspx
#4 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 29 June 2018 - 09:44 AM
Thanks, I guess i will need to check it all out.
It is actually pretty annoying.
#5 nicklouse
  • 18,682 posts
Posted 29 June 2018 - 10:57 AM
first thing I would do is slap some grease in the shift housing.
#6 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 07 August 2018 - 10:24 AM
That seems to have solved it! cheers for the tip Nick
