And either replace the diaphragm or the unit.
here is mine. it also explains the over fueling issue i had.
crispy
and dont know what was going on with the spring.
Posted 01 July 2018 - 07:28 PM
How long was yours on the car for?
Posted 01 July 2018 - 07:31 PM
since about 1995
Posted 01 July 2018 - 07:34 PM
Ah, well I'll check mine in 10 years then!
Posted 01 July 2018 - 08:28 PM
Hi,
Happens to all regs, even injection ones. Makes finding over fuelling problems that bit more interesting!
Posted 01 July 2018 - 09:16 PM
Oh Nick, you've got such lovely smooth hands
Posted 01 July 2018 - 09:19 PM
i have some loverly orange gloves. so i can look presentable at work on a Monday.
Posted 01 July 2018 - 10:56 PM
Another 3 reasons to bin them...
The diaphragm can crack split or leak
Creates a potential fire hazard
You probably can't get a new diaphragm
With a low pressure system (all carbed Minis) I see zero reasons for a regulator
Posted 01 July 2018 - 11:21 PM
you can get new diaphragms. was fitted before this new fangled fuel was brought in. and yes i have found them very beneficial over the years. will be replacing it with another but without the filter as 3 in the line is a bit much. also as the IDA does not like much more that 4PSI and the pump i use can supply about 6PSI i find them beneficial. and yes running a pump with less pressure has seen fueling issues at Harewood. but it all comes down to the build and the application.
