Oil Consumption
21 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 18 July 2018 - 06:58 PM
be interested to know what your getting on your mini. changed the oil up to top mark after 1000 miles used 250ml. using vr1 and Zx1 extralube. 1275 rally /race head mg metro cam honed and new rings 26000 miles ago
#2 Stevie W
Stevie W
  • 1,203 posts
  • Local Club: P&SMOC
Posted 18 July 2018 - 07:27 PM
Hi Bob,
Just completed 500 miles running in my engine in on cheap 20w50 oil and hardly used a drop and it doesn't leak any oil (yet)!
Going to have to get round to changing over to a decent oil soon and start giving it the beans!
Your consumption sounds very low too.
Cheers, Steve.
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 18 July 2018 - 08:08 PM
Sounds about right if it's got a selector leak.
My 998 with 100,000+ miles is weeping from the oil filter seal(all my minis do, just a light dampness bit filters are tight) and the gear selector seal... It done 500 miles over a weekend and used about 150 ml... My dad's Yamaha motorcycle used 1 pint per 1000 miles running
#4 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 18 July 2018 - 09:26 PM
I would say that's not bad, about right too me.
#5 Dusky
Dusky
  • 5,322 posts
Posted 19 July 2018 - 06:11 AM
Hi Bob,
Cheers, Steve.
Whats the point in using a cheap oil at the time an engine needs the best conditions possible? Makes.no.sense.
#6 GraemeC
GraemeC
  • 7,438 posts
Posted 19 July 2018 - 07:26 AM
Because friction modifying additives in good oils prevent the rings bedding in properly.
#7 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 19 July 2018 - 10:17 AM
Yes, and also the main bearing shells
#8 Dusky
Dusky
  • 5,322 posts
Posted 19 July 2018 - 10:48 AM
Bs. Sorry.
There is proper running in oil, bearing shells dont bed in.
Your cheap oil is the perfect to ruin a cam ( and the rest of the engine while the shrapnel is pumped round and round). Maybe its me,but I cant see why people skimp 25£ on oil after putting 100's in an engine.
#9 Stevie W
Stevie W
  • 1,203 posts
Posted 19 July 2018 - 06:33 PM
Dusky,
I was recommended cheap oil for running in the engine. The cam was bedded in by starting the engine and holding the revs at 2500 for 20 minutes. The engine is now run in and will now benefit from dropping the oil and re-filling with a good quality oil.
It pulls like a train and is one of the quietest A+ engines I’ve heard.
Cheers, Steve.
#10 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 20 July 2018 - 10:48 AM
Bs. Sorry.
Yes they do, to match the crank shape.
I use comma classic oil, £16 a gallon... Does the job
#11 gazza82
gazza82
  • 3,014 posts
  • Local Club: TMF+
Posted 20 July 2018 - 11:52 AM
If they don't match the crank shape when you fit them, the crank needs regrinding .. it should be perfecting round. This is also why some engines need the bearing caps line bored to make sure they too are round and don't deform the shells when you tighten them.
#12 Dusky
Dusky
  • 5,322 posts
Posted 20 July 2018 - 01:02 PM
Bs. Sorry.
How would they match the shape of sa reciprocating part? Again, BS.
#13 Minigman
Minigman
  • 779 posts
Posted 20 July 2018 - 02:41 PM
My newly built 1132 is using about 1litre per 100 miles.
Think it’s knackered already!
#14 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 20 July 2018 - 03:19 PM
Something isn't right there ?
#15 Minigman
Minigman
  • 779 posts
Posted 20 July 2018 - 07:24 PM
I know. It’s a bit of a nightmare!
